Gear selector is sticking
Old Sep 3, 2019 | 05:49 PM
jomo's Avatar
Default Gear selector is sticking
Hi,
I was out of town for 5 weeks and did not drive my Jaguar during that time. Upon returning I noticed that the gear shift was sticking a bit. It has loosened up a lot since then but it is doesn't go into park very well. It does go into park enough to remove my keys but I still have two problems. First the car will roll backwards a few inches if I am on a hill and 2ndly the car does not start most times if I am in park. It starts as usual if I start her in nuetral.
I was wondering what to do to free up that selector a bit more.
Thanks in advance,
Jomo
Old Sep 3, 2019 | 08:16 PM
motorcarman's Avatar
Since you are in UPSTATE NY I would guess a rusty/corroded selector lever cable??
I would disconnect the cable at the gearbox and see if the lever moves freely or the gearbox lever is the problem. (My bet is on the cable)
Could also be a fault with the selector housing but???????
bob
Old Nov 13, 2020 | 11:57 PM
CheekySmurf's Avatar
Default Did you find the answer
Hi Jomo
may I ask if you found the answer to your question regarding the gear selector sticking?
thanks
Colin
Old Nov 14, 2020 | 10:11 AM
jomo's Avatar
Originally Posted by CheekySmurf
Hi Jomo
thanks
Colin
Day by day it got better and now it is fine again. I just used it to get it better.
Biff Baxter
19
Feb 28, 2018 03:20 AM
trevor24
Oct 8, 2017 01:44 PM
vsol
Mar 24, 2016 07:37 AM
othuz0000
Dec 29, 2013 09:41 AM
XavierJ
May 20, 2011 02:53 PM
