Got hit by loose metal off semi-truck
Old Mar 11, 2017 | 03:31 PM
JensenHealey's Avatar
Default Got hit by loose metal off semi-truck
On my way home from dropping my stepson off at a local airport I was in the left lane behind another vehicle and both of us were passing a semi-truck. Suddenly a huge piece of loose metal comes flying back, the vehicle in front of me runs it over and it flips up and hits my 1997 XJ6 which I had almost all of the reconditioning jobs finished so I can start enjoying the car. Now I have a bunch more work to do and parts expense.
So at the next exit I pulled over and got out to look at the car. The front edge of the fender, the right hand headlight assembly are all toast. Plus there is a dent in the passenger's door.
See the attached photos
Attached Thumbnails Got hit by loose metal off semi-truck-img_1336.jpg   Got hit by loose metal off semi-truck-img_1338.jpg   Got hit by loose metal off semi-truck-img_1339.jpg   Got hit by loose metal off semi-truck-img_1337.jpg
Old Mar 11, 2017 | 04:00 PM
AL NZ's Avatar
Pretty bad luck.
I have had several broken headlights from stones (about NZD$200 secondhand, and left kidney price new), and broken plastic strip in lower grill from a rock. These plastic strips are not available in NZ secondhand..
But I haven't had bent metal like you.
Old Mar 11, 2017 | 04:03 PM
Doug's Avatar
Ouch !
On my X300 I had to replace several headlights over the years. They're susceptible to being hit with debris.
Old Mar 17, 2017 | 07:24 AM
Roger95's Avatar
I have two complete headlight assemblies from my ;96 Vanden Plas.
If you're interested in one or both for your repair let me know.
Roger
Old Mar 17, 2017 | 08:12 AM
Bad news but, looking at the level of damage, lucky it didn't hit the windscreen instead of the side of the vehicle.
Old Mar 19, 2017 | 02:38 PM
Default Found fender
I found a replacement fender at a wrecking yard in Pittsburgh PA. In the attached photo the color appears much lighter than it really is in real life. It turns out the color is a pretty close match for the color of my car. The cost was $60 plus tax but I had to drive down into downtown Pittsburgh to pick it up which was around 1.5 - 2.0 hours each way.
