Hard to explain............
Old Mar 15, 2014 | 11:44 AM
Don B's Avatar
Originally Posted by aholbro1
Did the vibe present after your wife drove the car? Have you eliminated a bent wheel as the source?
Since we have full-size spares in these, maybe put the spare on and move it through each of the four positions to see if any effect?
Another very good possibility, aholbro1! Also, a tire with a separating steel belt or other internal damage can look good but cause vibration.
Old Mar 15, 2014 | 11:56 AM
aholbro1's Avatar
Originally Posted by Don B
Like others I suspect your vibration is driveline-related, but a failing fuel pressure regulator could allow the pressure at the fuel rail to fluctuate and lead to uneven cylinder combustion...... I found an OE Bosch FPR for under $100, but other brands are available for as little as $40.
Don
Interesting thought, Don! That may well explain what I call a "stumble" observed a couple of times this week; Cruise-control, setpoint 70 mph, there would be a noticeable on any downslopes or anytime the control decided the throttle need be retarded a bit. Switched to manual and repeated the behavior, stumble anytime I eased off the throttle. Then the problem vanished. Could be due for a throttle body cleaning, though, as I believe I completed the last one around 85k mi, now sitting at 147k.
mikiep
Dec 20, 2019 07:37 PM
Johnken
Apr 8, 2018 10:21 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
Johnken
Oct 2, 2015 10:12 AM
JTC3400
Sep 29, 2015 05:03 PM
