Headlining installation
Old Jun 8, 2013 | 07:54 AM
spencerikin's Avatar
Default Headlining installation
Hi All
So I ordered a new headlining, took the old one out with no trouble at all although I had to bend it a little it, but I can't get the new one it. It's a lot stiffer and won't bend.
Any ideas?
Urgent help needed.
Spencer
Old Jun 8, 2013 | 07:55 AM
mikesmith2's Avatar
You will need to bend it. Don't be frightened just careful.
The only other option is to remove a screen.
Which door are you trying to put it through?
Old Jun 9, 2013 | 01:56 AM
Really? It's loads stiffer than the board I removed. The old one felt like an egg carten while the new one feels like fibreglass. It's hardly bends at all, I'm really worried about snapping it. I was trying to feed it in the passengers front door, the same as the old one came out of.
Old Jun 9, 2013 | 02:13 AM
FireCrow's Avatar
well, if it is FG as you say, then the only way to get it in is take the glass out...
Old Jun 9, 2013 | 02:34 AM
mikesmith2's Avatar
I found there is more room if you use the rear door.
I did mine through the rear drivers door, it gives a better angle and you only need to slightly bend it length ways.
Put both front seats as far forward as possible then recline the backs as far as possible.
Old Jun 9, 2013 | 02:54 AM
Really Mike? You had a brand new one made of what looks like fibreglass and you bent it? I've got a standard wheelbase 1997 3.2 executive. The manufacture of the board said either take the passengers front door off and take the passengers front seat out. Or the rear window. Neither options sound great, but got a guy who can do the window for £60 so I'm thinking of doing that option.
Old Jun 9, 2013 | 04:07 AM
mikesmith2's Avatar
No not a new board, recovered my old one,
Try using the rear door as the angle is much better and it's only a slight bend thats needed that way.
Old Jun 9, 2013 | 12:07 PM
XJR Prototype's Avatar
I'm dreading doing this... local interior shop said unless the rear window comes out you'll have to live with a small crease in the middle... so... looks like the rear window will come out haha.
Old Jun 9, 2013 | 03:27 PM
mikesmith2's Avatar
If you are recovering the original board there will be no crease visible.
Using the rear door to remove and replace the headliner means very little bend is required.
Old Jun 9, 2013 | 03:29 PM
Doug's Avatar
I agree. I creased my board a bit but it's invisible under the new headlining material. I guess it might depend on just how badly creased it is.
Old Jun 9, 2013 | 09:07 PM
sparkenzap's Avatar
+3 for me. I have done three X-300 or X-308 headliners, and I actually folded one nealy in two with the crease being side to side at the middle of the sunroof hole. By some light massage and finess (of which I am sorely lacking) with my finger tips, it is impossible to see the crease.
Old Jun 10, 2013 | 08:05 AM
Right then - rear window removal.....
Are the bonded or in a rubber seal with a spreader. I've got a P reg.
Spencer
Old Jun 10, 2013 | 11:03 AM
mikesmith2's Avatar
If it's bonded you stand a good chance of breaking it trying to get it out.
Also remember that the receiver aerial for the remote fob is in the glass along with the heater element.
Old Jun 10, 2013 | 12:55 PM
mgb4tim's Avatar
getting a new windshield in mine tomorrow. 18 years of stone chips - gone!
Old Jun 10, 2013 | 05:43 PM
Spencer
So is it stuck in with glue or just a rubber?
Old Jun 10, 2013 | 11:30 PM
mikesmith2's Avatar
Mine doesn't look bonded, but you won't know until you take the chrome strip out.
Another way to tell is look for a join in the rubber strip. join = not bonded
Old Jun 11, 2013 | 01:47 AM
Well I don't remember seeing a joint in either the rubber or the chrome. Also the glass has a black ring around the edge which a colleague of mine says that means its probably bounded as that's added so you can't see through the glass to the body work.
So is it easy to removed and replace a bonded screen? Assuming it is?
Old Jun 11, 2013 | 01:53 AM
mikesmith2's Avatar
If its bonded then it has to be cut out, never seen one come out in one piece though.
If it does then the original adhesive needs to be cleaned from the body and the glass, one back in place it needs to be left for awhile before you drive the car other wise you could end up with a water leak.
Jose
Dec 18, 2021 08:16 AM
Tony K
Apr 2, 2020 11:55 AM
King Charles
Apr 16, 2017 11:10 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
graham11
Sep 7, 2015 03:04 PM
