Heater hose motor
Old Aug 26, 2018 | 04:07 PM
44lawrence's Avatar
Default Heater hose motor
My little motor in the heater hose probably needs new brushes. I'm getting very little heat from my 95 X300 4.0. .I looked through the archives & found all the motors look to be bigger than mine.On mine the round top part is 1 1/2 " in diameter by 1 1/2" high, Just wondering, is there more than one type/size of these motors & if mine can be rebuild mine?
Old Aug 26, 2018 | 09:56 PM
Lady Penelope's Avatar
Bosch motor units where peoduction replacments later on the X308 at year X .
The bru for the original 3are 3A keeping in mind there is a flow control valve
Old Aug 27, 2018 | 12:06 PM
44lawrence's Avatar
I was looking @ the wrong thing, Don't know what that other little cyl thing does though. I see the motor below, it looks the same as the ones in The Archives repair pic's. Thanks guys.
Old Aug 28, 2018 | 02:12 AM
SleekJag12's Avatar
The other smaller cylinder is the heater valve. It opens to allow heated coolant into the matrix while the pump pumps it through. The valve can open and close automatically to maintain a certain flow through the matrix if your Climate Control is set to Auto. Of course it operates "manually" by changing the temperature setting while not in Auto mode. Neat.
Old Aug 28, 2018 | 08:09 AM
iN HOSPITALAL YTRYING
Old Aug 28, 2018 | 08:20 AM
44lawrence's Avatar
I was wondering what that did after I found the motor I was looking for, thanks for that info, yes interesting. So, how reliable is this heater valve ? Seems like we should make brushes part of the 100k maintenance program in the other motor. I see a lot about this motor failing on The Forums.
In "olden days" the heater hose went into the matrix from the block & back to the block without any fanfare "stuff" & the cabin got hot, high tech?????
PS. LP Hospital ??
Old Aug 29, 2018 | 05:03 PM
Old Aug 29, 2018 | 05:24 PM
Robman25's Avatar
From my understanding item 3 is a solenoid rather than a motor so no brushes in there.
Old Aug 29, 2018 | 06:04 PM
In hospitalt develope understanding slowly
Old Aug 29, 2018 | 06:09 PM
Yes . Feeld modules and nton / off Solinoiwater flow difection by heat value in the hose .
Sensor in cbin getts dirtu
hit mptor for spin upp[.
Old Aug 29, 2018 | 09:48 PM
A33 bushing x 2 if needed
Look for control fuses .
Old Oct 20, 2018 | 02:47 PM
44lawrence's Avatar
Default Aux heater motor
Thanks LP for your info on where to find these "33A " brushes for the heater hose motor. Perfect fit, $20.
44Lawrence
Old Oct 20, 2018 | 08:42 PM
Someone else passed it along as mine had a folded over and pinched off hose back behind there
kthrash
Dec 31, 2018 11:31 AM
shanshan
Dec 8, 2013 10:10 AM
Dan R
Oct 29, 2010 06:31 PM
m0t0rm0uth
Nov 20, 2009 02:27 PM
