Heater hose motor
Heater hose motor
Finally got working on the heater hose motor. Bench test showed it was working but since its out I might as well put new brush's in it. Does anyone know a way the brush is removed (after the wire is cut) & installed in that brass cage? The brush wire is the holdup. Also where are the brush's sold.
Since the motor checked out OK on the bench anyone have other thoughts? I do get some heat but only when the car is "slow moving". BTW this is a 95 4.0 six cyl
There is a water solenoid that is not full open or closed but modulated by the AC ECU to maintain a constant cabin temp
Brushes are 33A X 2 from a company in California
.15" x .15" x .35" BRUSH 33A
There is a good picture loaded post on brush replace
Jaguar XJ6; Jaguar X300; Heater Pump
https://www.jaguarforum.com/showthre...=84821&page=2&
mentwnd cap is probably swelled and won;t go back in but they can be found at the hardware store as common rubber
The large thin o - ring on the
there is a self test on the AC control head that will give you fault codes to look at the heater components
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
The proper modulation of the water solenoid depends on a clean cabin temp sensor located as the 1 inch square vent on the panel below the steering column
Editing
Took out the three screws, lower housing off , problem being the armature will not slip off of the armature bearing & the bearing is bigger than the "bakelite" hole to fit through with the bearing still on the armature, therefore the armature won't come out of the brush housing. I don't want to force or beat on anything with fear of braking something. Any plan "B" gents ?
kthrash
12-31-2018 11:31 AM
shanshan
12-08-2013 10:10 AM
m0t0rm0uth
11-20-2009 02:27 PM
