HELP: Name this part - throttle body
Old Oct 29, 2015 | 02:32 PM
SD96XJ6L's Avatar
Default HELP: Name this part - throttle body
I can't figure out where this part came off my 1997 XJ6 4.0 NA throttle body.
Is it a seal for the Intake Air Control Valve?
It is rubber and has the following #'s stamped into it:
DSL23 / 277-93J
This came off when dis-assembly of throttle body on 4.0 6 cyl NA engine.
Old Oct 29, 2015 | 06:34 PM
aholbro1's Avatar
hmmm....if it wasn't rubber, I'd say it is the keeper for your throttle-return spring - the one you have to either modify or replace to mend the high-idle/throttle doesn't return issue
Old Jan 11, 2016 | 01:14 PM
SD96XJ6L's Avatar
Bump. I still can't figure this out. Perhaps a better image would do:
Where does this go on the throttle body housing of an X300 4.0 I6?
Where does this go on the throttle body housing?
Teck4Jag
Jan 7, 2018 12:32 PM
phil200tdi
Nov 3, 2015 04:22 AM
Andrew Pearce
Nov 2, 2015 02:35 PM
BuggMan
Oct 31, 2015 11:58 PM
Jon89
Oct 31, 2015 04:28 PM
