How to lubricate throttle cables
Old Jun 1, 2014 | 11:25 PM
al_roethlisberger's Avatar
Question How to lubricate throttle cables
Have read most of the throttle body cleaning and cable adjustment threads, and although many have mentioned lubricating the cables I don't think any specified how or with what.
Does anyone have a recommended lubricant for the throttle cables and best way to get the lubrication through their length?
I've seen many cables on motorcycles gummed up by well meaning owners using the wrong lubricants.
Old Jan 12, 2016 | 08:08 PM
Resurrecting an older thread; brought this question to mind when I was dealing with my throttle issues.
So, is lubrication of the throttle cables a maintenance item, or is it not recommended?
Old Jan 12, 2016 | 09:42 PM
caldercay's Avatar
Hilarious, in one respect, related to bikes, as I own 5 and have ridden all from motocross to street bikes.
This probably comes across old school, but I would recommend how we do it motorcycle-wise - though it only applies to bikes with cable systems
http://www.motionpro.com/motorcycle/articles/view/340/cable_maintenance_101/
Old Jan 12, 2016 | 09:47 PM
plums's Avatar
Don't know why it wasn't clickable.
so here:
Motion Pro
Old Jan 14, 2016 | 12:37 PM
Motion Pro
Thanks, yeah I think I still have some of that stuff around
Just wanted to make sure the Jaguar cables even should be lubricated, so that some sort of lubrication wouldn't deteriorate the lining (if they are lined), etc.
Old Jan 14, 2016 | 06:39 PM
caldercay's Avatar
Just wanted to make sure the Jaguar cables even should be lubricated, so that some sort of lubrication wouldn't deteriorate the lining (if they are lined), etc..
The Motion Pro stuff is highly rated - I can't imagine Jag uses any special interior lining in the cable (but don't hold me to it).
I have motorcycle (mostly dirt bike) friends who inject dry lube into cables as an alternative to the dedicated cable stuff.
Fortunately, all my bikes (well, sans one bike) use DOT4 hydraulics for clutch and brake operation vs cables
Old Jan 14, 2016 | 11:46 PM
Don B's Avatar
Al,
I share your reticence because I think I recall reading somewhere (maybe in Jaguar service documentation) that cables should not be lubricated with an oil or liquid lubricant of any kind because the lube will tend to attract dirt and grit and eventually foul the cable. I assume dry graphite might be acceptable, but getting it distributed inside your cable might take some creativity.
I'm intrigued by the link caldercay shared - very interesting!
Cheers,
Don
Old Jan 15, 2016 | 07:45 AM
caldercay's Avatar
Originally Posted by Don B
Al,
Don
Distribute via "compressed air", either by can or compressor: inject the graphite into cable, then use the compressed air to push it through - that's how my dirty biker friends do it at the track (or home).
One thing to consider, though - graphite, when wet, will also "gum up".
If a cable is suspect, why not just replace it? Sourcing an original Jag cable might be difficult to find (or cost prohibitive?), you could have one made up. Case in point - a power-steering hose on my Jag developed a leak. I had one custom made at a hydraulic hose shop (in Katy, TX). It cost me the same as a genuine Jag hose, I had it within an hour, and it will last much longer than my Jag or me.
Old Jan 15, 2016 | 08:43 AM
Don B's Avatar
That's an excellent suggestion. The racing suppliers like Summit and Pegasus carry kits for making up your own throttle and kickdown cables.
Old Jan 15, 2016 | 12:16 PM
Jagboi64's Avatar
A lot of cables have a teflon lining inside the sheath, so don't need lubricating.
Old Jan 15, 2016 | 04:12 PM
plums's Avatar
I think that the motorcycle side does not consider fouling
from accumulated dirt because it is meant to be performed
regularly. The dirt flushes out with the old lubricant.
Old Jan 16, 2016 | 06:56 PM
cool's Avatar
throttle cables are serviceable and clean via
1. cleaning first the ingress and egress of the cable ends using WD40 and the likes
2. use Wurth contact cleaner SL and spray on the expose stranded cable simultaneously pushing and pulling the metal spiral cable to allow the contact cleaner (or any other acetone or alcohol base cleaner) reach into the first few inches part of the cable insulator, simultaneously wiping off any dirt that shows up on the expose cable. normally dirt do not travel/get into the middle section of the cable.
Throttle Cables were never meant to be lubricated, to avoid sticking, gumming and solidifying of dirt within the in and out of the cable insulator.
If operation is no longer smooth, replace cable.
jimforrest (uk)
Feb 28, 2019 06:42 PM
MrWhite
33
Oct 22, 2015 10:29 AM
tomkilner
Oct 9, 2015 07:10 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
