How should i go about do this job VDP 96 tie rod ends
Old Jan 8, 2014 | 03:02 PM
vandenplas408's Avatar
Default How should i go about do this job VDP 96 tie rod ends
so i just
disconnect the neg battery terminal
loosen Locking nut to tie rod end but do not move it really since
new tie rod need to set in same spot as old?
take nut off the tie rod end press the tie rod end out
screw new one up to locking nut and lock the nut onto the old spot
then place the tie rod back into suspension and tighten the nut on top?
this seem pretty easy and straight forward
i will make a pic tutorial asap once i do this.
i already have parts just need any tips/ pointers
Old Jan 8, 2014 | 04:19 PM
AllanG's Avatar
Originally Posted by vandenplas408
so i just
Yes you just back off the rod nut then I like to mark the point where the nut met the tie rod end. Then you loosen the top nut of the tie rod end but do not remove it. Using a ball joint tool or a hammer get the ball to break with the joint then remove the top nut completely.
Then unwind the tie rod end from the tie rod. To be safe I like to count the number of turns. Then screw on your new tie rod end, it should be the same number of turns that take it up to your mark. Then fit the end into the knuckle and tighten the top nut and the tie rod end locking nut. Done.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
Dicque
Sep 12, 2015 10:34 AM
JagLove86
Sep 6, 2015 10:36 PM
