Identifying XJ6 powersteering rack by casting numbers,
Old Jun 4, 2026 | 01:19 AM
Clifford Hunt's Avatar
Default Identifying XJ6 powersteering rack by casting numbers,
I have an XJ6 powersteering rack RHD from a wreckers but no Vin numbers etc this rack needs a rebuild so I need to identify it and then order a kit for it.
The Pow-A-Rak pinion end casting number is HB27851 the other end casting is HBOO241.
If one of you kind gentlemen could help me out with this please it would be appreciated.
cheers and thaans in advance.
Photo of pinion end casting number.
Old Jun 4, 2026 | 09:24 AM
Parker 7's Avatar
X300 XJ6 ? of the years 94.5 to 97 ?
Don't know if you need the casting # but someone took a pic of the hard to get to data plate
So , you see the 7852 primary whole unit part # someone took a pic of and I hope this helps , not known if this is a servo version or not
Old Jun 4, 2026 | 09:31 AM
Parker 7's Avatar
And the service manual
You can get power steering fluid from above rack at the under reservoir fittings that get blown everywhere miss leading to think it is the rack , you can cut off an inch or so of old hose for some fresh meat
File Type: pdf
Clifford Hunt
Australia - Western
Jun 4, 2026 01:05 AM
farina43537
Mar 6, 2024 07:44 PM
enomadra
Nov 22, 2023 06:47 PM
NJ2003XJ8
Jun 26, 2019 07:03 PM
alboerner
Jul 28, 2014 04:01 PM
