Immobiliser programming sequence
Old Nov 3, 2023 | 06:12 PM
willbot's Avatar
Default Immobiliser programming sequence
Hi, I've got a replacement chip key cut for my 1996 xjr6, is there a sequence I can follow to program the new one in? I've heard a couple different techniques, not sure which one would be applicable for my car
Old Nov 4, 2023 | 04:35 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
The Security Locking Control module (SLCM) must be programmed to match the transponder chip in the ignition key using dealer level software on vehicles outside of the USA that use this security. Unfortunately there is no simple way to pair the new key to the module.
Old Nov 4, 2023 | 07:32 PM
willbot's Avatar
Shoot Is it possible to disable or bypass altogether?
Old Nov 5, 2023 | 05:02 AM
V126man's Avatar
Andy Stodart is an ex Jaguar engineer on this forum.
He is based in the United Kingdom and I believe that he can modify the ECU to remove the key security.
This is the link to his member details https://www.jaguarforums.com/forum/m...gineer-113530/
Old Nov 5, 2023 | 11:35 AM
944play's Avatar
Is it not possible to secure the working key's head/transponder pill to the back of the antenna? IDK, I've never owned an immobilizer-equipped car.
Old Nov 6, 2023 | 01:41 AM
willbot's Avatar
Thank you for the pointer
Seems like a better route than programming a key, have been thinking about buying a bracket from him too
Old Nov 6, 2023 | 03:33 AM
V126man's Avatar
Good idea.
This would probably work although I am not sure if the security chip could be removed from the original key (if there is one) without damaging it. A solution may be to remove the transponder exciter ring from around the ignition switch and attach it in close proximity to the head of the original key.
willbot
Sep 26, 2023 08:56 PM
Len Apcar
Aug 16, 2023 05:22 AM
Stephen Harron
XE ( X760 )
Feb 4, 2020 01:49 PM
bone64
Dec 6, 2011 04:20 PM
jevs
Oct 8, 2009 12:35 PM
