just bought a X300, check engine on
Old Dec 4, 2017 | 08:34 PM
xjfourty's Avatar
Default just bought a X300, check engine on
Hello,
just bought 95 a X300 with 71000mi.
So Now I have a xj6 III and xj6 X300.
Payed $3200.
it has check engine light on. Mechanic inspected it and said it is because regular gas is being used. He told me to put a full tank of premium gas, drive it good at least half tank with premium gs up to 85mph, then come back to him to reset the check engine light.
Does it look reasonable to you guys?
thanks a lot
Old Dec 4, 2017 | 08:47 PM
Lady Penelope's Avatar
Auto part store will read and reset it for free as they want to sell you some parts . Write all the codes down .
Old Dec 4, 2017 | 11:27 PM
xjfourty's Avatar
Hello, yes the mechanic told me the code (I don't remember it) was meaning bad gas I'll ask him the code again thank you.
Old Dec 5, 2017 | 03:10 AM
countyjag's Avatar
These cars will run happily on regular or premium gas, so I would say further investigation definitely required. Do you have the specific code number which the mechanic says is present?
Old Dec 5, 2017 | 01:19 PM
motorcarman's Avatar
Do your self a favor and buy a cheap $15 OBDII DTC reader from eBay or some place like that.
https://www.ebay.com/itm/Scanner-Dia...QAAOSwC9VZgzJG
https://www.ebay.com/itm/U480-CAN-BU...UAAOSwImRYdz~l
You won't have to rely on someone else and can actually clear DTCs after diagnosis and repair.
bob
Old Dec 6, 2017 | 12:09 AM
SleekJag12's Avatar
Default Bad gas?
I don't recall a code for "bad gas"! And regular unleaded isn't necessarily "bad". Why couldn't he reset the code right then? Looking for repeat business perhaps? And for how long do you have to drive at 85mph?
Welcome to the modern/classic world of the X300. It has first generation OBDII which can be useful for diagnosing problems! You'll want that code reader. Post a picture for us?
Old Dec 7, 2017 | 09:06 PM
xjfourty's Avatar
yeah I am going to buy it really. Thank you.
when I have it I'll read the code and post here.
thank you
Old Dec 7, 2017 | 09:10 PM
xjfourty's Avatar
ok I just bought the KW806 scanner. I'll have it on December 13.
I'll keep you posted really thank you for helping!
Old Dec 22, 2017 | 01:46 PM
xjfourty's Avatar
update: the mechanic smogged the car. So he told me that it was too rich, after smogging it then he put the settings back as before because the car was running much better slightly richer. I did almost 1000mi after putting premium gas and check engine light did not come up again.
Old Dec 22, 2017 | 02:12 PM
Something that won't show up as a code is fresh high O2 air being sucked in between pulses ( at idle ) at a cracked exhaust manifold or downpipe donut gasket seats causing the O2 sensor to bias the mixture rich . This would be seen as a short term fuel trim higher the 0.0 and can be observed with a ELM327 adapter to your laptop .
Another thing is the ECT sensor biases the mixture rich by design until the coolant temp heats up . The sensor is a thermistor and can be calibrated easily or the connector can be dirty causing higher resistance mimicking a colder coolant temp . A thermistor works opposite a temp variable resistor as the higher the resistance is a colder reading . Clean the exposed connector
Old Dec 22, 2017 | 04:25 PM
xjfourty's Avatar
Omg if it is a cracked exhaust mainfold I guess it's crazy expensive to replace...
Old Dec 22, 2017 | 04:36 PM
Just pull the cover to find out as you run the engine. Mapping out a cheap repair
Old Dec 22, 2017 | 04:37 PM
xjfourty's Avatar
if I remove the cover should I see with my eyes if there is a crack ?
Old Dec 22, 2017 | 04:53 PM
Not always but better if it's heated up . Then there's the puffs of black smoke if it is leaking and the mixture is rich not combusted after coolent temp rise above a certain value
Old Dec 28, 2017 | 09:56 PM
xjfourty's Avatar
Ok after 1600mi check engine light showed up again.
I Stopped at O'Reilly and the OBDII scanner read this error:
P0420: Catalyst System Efficiency Below Threshold Bank 1.
is my cat converter gone ?
Old Dec 28, 2017 | 10:22 PM
Since you suspect that your running rich the Cat and sensors could be sooted over . The 420 and 430 come from from the aft O2 sensors . I personally would leave it alone until you get the STFT back to 0.0 . The fwd sensors from what I understand are the ones that do the STFT regulation and you can soak in gasoline overnight washing some gas into the vent holes where the sensor is . There is the 2 connectors that can be easily crossed and will cause engine regulation issues from Jacklynthejag's experience . Missing crush washers on the aft sensor biases the signal as they are 12 mm spark plug size
Editing
Old Jan 3, 2018 | 01:57 AM
xjfourty's Avatar
ok, may I have some hint on how to connect a laptop to read the STFT and LTFT ? with dash command and ELM327 wifi would I be able to read those values on a ipad or iphone ?
thanks
Old Jan 3, 2018 | 11:31 AM
The software is different for each manufacturer and there are Youtube videos that may help . There may be a default configuration already set up of PID's ( perimeters ) that have the STFT ( you need both banks ) don't worry about LTFT . It's a learning curve thing
PID's important for engine regulation :
RPM
MAF
TPS
ECT
IAT
STFT bank 1 and 2 - this is the end result of the above sensors which includes the O2 sensors but I could never get mine to read before the licence key dropped out
Old Jan 3, 2018 | 02:13 PM
Vee's Avatar
Vee
I believe it is the downstream sensors that do the heavy lifting. There are threads that confirm this.
I thought it was the upstream sensors until I was corrected here.
https://www.jaguarforums.com/forum/x...ensors-173577/
