Key cutting key tibbe stripped
If you are sure it is not the lock barrel itself spinning? Then your, probably, only choice will be to provide the VIN to the dealer and have them cut a new key. With that you can get cheaper duplicates from a locksmith.
Welcome to the forum julandnic,
I've added vehicle details and moved your question from General Tech Help to X300 forum. This is the place to post questions about your model.
You can follow instruction from this seller and get key code and cut.
https://www.ebay.com/itm/JAGUAR-DAIM...MaWU:rk:8:pf:0
https://www.ebay.com/itm/90-97-Jagua...bUs:rk:23:pf:0
osyris
May 28, 2016 06:20 AM
