Key cutting key tibbe stripped
Old Nov 3, 2018 | 12:49 PM
julandnic's Avatar
Default Key cutting key tibbe stripped
its spinning on ignition help
_________________
1996 XJ6 (added by GGG)
Old Nov 3, 2018 | 03:13 PM
avern1's Avatar
If you are sure it is not the lock barrel itself spinning? Then your, probably, only choice will be to provide the VIN to the dealer and have them cut a new key. With that you can get cheaper duplicates from a locksmith.
Old Nov 3, 2018 | 03:52 PM
Welcome to the forum julandnic,
I've added vehicle details and moved your question from General Tech Help to X300 forum. This is the place to post questions about your model.
Old Nov 5, 2018 | 02:04 PM
annamiata's Avatar
You can follow instruction from this seller and get key code and cut.
https://www.ebay.com/itm/JAGUAR-DAIM...MaWU:rk:8:pf:0
https://www.ebay.com/itm/90-97-Jagua...bUs:rk:23:pf:0
baliniere
Oct 23, 2016 05:35 AM
Robert Grisar
Oct 6, 2016 03:16 PM
osyris
May 28, 2016 06:20 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
May 9, 2006 10:54 AM
