Key Locked in Trunk - It's Not The Valet Switch - Help Me!!
Old Apr 4, 2008 | 09:24 PM
RalphFurley's Avatar
Default Key Locked in Trunk - It's Not The Valet Switch - Help Me!!
This really sucks:I locked my only regular key in the trunk while I was replacing the trunk microswitch. The new microswitch was in, but the dashboard release latch and electronic trunk badge release still didn't work. So I closed the trunk once more to try it again, and as soon as it shut closed, I thought, "Damn". I have a valet key, but that doesn't open the trunk. I even tried disconnecting the wiring to the valet switch to see if that would do anything. Also, when I bought it used, it didn't have a key fob, just a black key and a green key. So I can open the doors and drive the car, but the trunk won't budge. I called my roadside assistance, but they said that they didn't have the equipment to make a hi-security key, and they didn't want to drill or break the lock for liability reasons. So what's the best way to get that thing open?
Thanks,
David
Old Apr 4, 2008 | 09:56 PM
stangman's Avatar
Default RE: Key Locked in Trunk - It's Not The Valet Switch - Help Me!!
The only difference between the green valet key and the black master key is the very end …the end of the master is smaller …it has a small ring cut around it …if you know some body with a jag take a look at there keys it is easy to see ..you can grind or file the ring very easy takes less than five minutes ….or get the dealer to cut you a new master from the valet key
Old Apr 9, 2008 | 01:29 PM
Thanks Stangman,
I was able to get a master key made from the valet key at the dealer. Thanks again.
Old Sep 6, 2012 | 03:21 PM
bliving7's Avatar
I just ordered a second master key for my 1996 VP from the dealer at $75. The dealer can order the key from Jag and if you give him the VIN the key will arrive already cut.
bliving7
dsnyder586
Dec 29, 2024 07:39 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
