Leaking Oil Pressure Sending Unit
Old Dec 26, 2013 | 01:15 PM
zubizar's Avatar
Default Leaking Oil Pressure Sending Unit
After owning my 2003 Jaguar XJR for two weeks, I have found a leak that appears to be coming from the Oil Pressure Sending Unit. Does anyone have a diagram as to where it is located and what size wrench (spanner) I need to remove and replace it? does it require a washer also? Thank you in advance and be kind to a newbie (me).
Old Dec 26, 2013 | 04:50 PM
Firstly welcome to real world.
Your 2003 belongs elsewhere, BUT, fear not, we have all done this in the past when we were newbies.
The 2003 is at the change point.
4ltr V8 is X308.
4.2ltr V8 is X350, and Aluminium body.
Repost would get a real quick answer, coz I dont know the answer on the V8.
One of the moderators will see this, once Christmas hangover dissipates, and move it for you.
Old Dec 27, 2013 | 01:03 AM
plums's Avatar
It is just north of the oil filter mounting pad.
On a 2003/XJR there may be two devices mounted there. The oil pressure switch and the oil temperature sender.
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
kelliott
May 31, 2022 05:26 PM
giandanielxk8
Sep 6, 2015 07:21 PM
