Leaper Removal
Old Jan 26, 2024 | 04:35 PM
odpuskas123's Avatar
Default Leaper Removal
Hey, I tried looking this up but I couldn't find anything clear. Is it possible to remove the leaper when I am somewhere where it is likely to get stolen, and then put it back on later?
How does the leaper come off? I have a 1997 XJ6.
-Thanks, Oden
Old Jan 26, 2024 | 04:39 PM
Parker 7's Avatar
I think if I remember stealing as simply a 17 MM plastic nut to remove
Old Jan 27, 2024 | 01:01 AM
Spud Maat's Avatar
24mm plastic nut
Easy accessed from underside of bonnet with regular socket.
Unless someone has also put double-sided tape on the underside of the leaper like i did on mine to ensure it stays pointed the right way.
Old Jan 28, 2024 | 02:45 PM
Originally Posted by Spud Maat
24mm plastic nut
If I take the double sided tape off, does it move around a lot and possible scratch the hood? Or is it okay to take it off?
-Oden
Old Jan 28, 2024 | 10:56 PM
Parker 7's Avatar
I think your will have a 2nd alignment pin hole in the bonnet to keep it straight .
The leaper did not come on all X300 models and his Australian model / market may have started that way even though it is a 4.0 liter engine
The tape may be to keep the leaper from fretting or rubbing the paint
You can keep the sticky side of a good duck tape on the leaper side only for a clean leaper removal
For a removal tool a set of channel locks will remove the 24 mm , cheap at Harbor freight
Old Jan 29, 2024 | 01:32 AM
Spud Maat's Avatar
Some AU models came with, some came without. most had it.
it may have been an optional delete.
certainly most down under have it.
Sovereigns did come with them however I feel it may not be the original bonnet on mine.
there is no alignment hole on mine.
i put the double sided tape to secure it and protect from scratching.
however removing it now has become extra hard as i will need to remove the tape carefully.
next time i will not adhere the leaper to the bonnet.
however i should only ever need to remove it to get my bonnet re-wrapped or repainted and then in that case it will not matter.
NYCJAG2006
Feb 22, 2022 07:37 PM
jeffp
Aug 11, 2016 09:41 AM
Wardhaddadin
23
Jan 4, 2016 10:42 AM
Skyjump136
Feb 4, 2014 01:30 PM
kgrosse
General Tech Help
Jul 21, 2010 05:56 PM
