LH turn signal/fog lamp not working
Old Dec 11, 2012 | 08:32 AM
AWDimprezal's Avatar
Default LH turn signal/fog lamp not working
My 1997 VDP has a fast flashing LH turn signal (front not working) bulbs are both new. Furthermore the LH fog lamp does not work either, bulb is also new, no blown fuses, is there a connector that may be corroded somewhere? This a common thing? Other than this I love the car, and it doesnt really have any other issues.
Old Dec 11, 2012 | 07:02 PM
Time to get down and dirty with the Jag.
Where the front undertray meets the LH guard and the wheel arch liner, in front of the wheel, it a multi pin connector.
There is one on each side of the car.
This WILL BE that problem. Spray it liberally with WD40 or similar, pull the 2 bits apart, check for corroded male/female connectors, clean as required, spray it again, reassemble, see what happens.
Common??, getting that way.
Old Dec 12, 2012 | 08:04 AM
Than you so much! I'll get her up in the air this weekend and check it out, thats a great perk of working in a shop, access to lifts and whatnot. I havent changed the oil yet, so I think I'll take care of that too.
Old Dec 12, 2012 | 07:16 PM
Sweet.
While you are at it do the trans/diff/brake fluid/power steer fluid, the components and the car will luv you for it.
Old Dec 14, 2012 | 10:26 PM
Changed the oil, and did a power steering exchange, disconnected and reconnected the connectors (in the LH wheelhouse) using wurth contact cleaner OL. Everything works! Thanks for the help! I'll be making a fresh thread soon about either converting my head unit to an excellent pioneer unit I took from my mercedes, or trying to figure out what is wrong with my current changer. Thanks to all, and stay tuned!
kelliott
May 31, 2022 05:26 PM
johnnie ryall
Oct 19, 2015 09:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
