License Plate Light
Old Dec 21, 2015 | 04:52 PM
Phil3814's Avatar
Default License Plate Light
I failed inspection today for a faulty license plate light (right/passenger side). I replaced the bulb and it's still not working. The left/driver side light does work. I'm guessing this is either a wiring or a fuse issue. I do not have an owner's manual so if someone could point me towards the location for the fuse(s) that operate that light I would be most grateful.
Thanks,
Brendan
Old Dec 21, 2015 | 06:44 PM
b1mcp's Avatar
I'm assuming that your tail lights are working as you didn't say they weren't. So that means it is not a fuse issue as they are on same fuse.
With Number plate lamps they can suffer from corrosion in the bulb holder. Try cleaning it well with what ever light abrasive you can get in there.
If you have a multi meter test for ground and 12v at the bulb holder and work backwards from there.
Old Dec 22, 2015 | 12:49 AM
Malihide's Avatar
Thanks,
Brendan
Hi Brendan,
If I were you, I would take off the carpeting on the trunk lid. You can easily see if there are any frays in the wiring there. Of course, this is assuming that the wiring on your trunk hinge is intact, as you haven't mentioned any problems there.
Old Dec 22, 2015 | 09:06 AM
dagny747's Avatar
I had this same issue, corrosion, last year and had to get a used one.
Old Dec 23, 2015 | 07:47 AM
Phil3814's Avatar
Have no power at the connector, and yes all other lights are working, so on to checking the wiring.
Old Dec 24, 2015 | 07:42 AM
knightofgold's Avatar
I had one of my number plate lights melt and fall out. They seem to get really hot.
Old Dec 24, 2015 | 11:46 AM
al_roethlisberger's Avatar
I also replaced mine with Sylvania LED lamps, so they run cooler. These are the Sylvania LED lamps sold as auto parts shops, not the cheap lights on eBay, etc.
obwoodie
Dec 12, 2015 05:51 PM
andyXJR
Nov 30, 2015 11:56 AM
JagGuyMD
Nov 28, 2015 07:13 AM
domino_z
Nov 27, 2015 08:40 PM
Addy
Nov 27, 2015 02:54 PM
