LNAAAA4144AB Harmon Kardon Rear Subwoofer Theoretical Replacement.
Old 10-01-2016, 12:05 AM
FerrariGuy's Avatar
Default LNAAAA4144AB Harmon Kardon Rear Subwoofer Theoretical Replacement.
While doing other projects I pulled out and tore apart my old broken LNA4144AB rear sub (which I replaced with a used OEM speaker) and measured the ohms/impedance values (which I cannot find cited anywhere.)
This is a thread for the benefit of others, and my future benefit if my 2nd rear sub ever blows.
Each coil on my rear sub measure at just about 5 ohms. I suspect a 6x9 with dual 4-ohm coils would suffice just fine, or two 4-ohm subs if the rear deck could be made to fit a left and right speaker.
As it so happens there now appears to be a couple of nearly direct replacement for as little as $75 with 2x 4 ohm connector sets on one speaker:
RetroSound R-69N DVC Dual Voice Coil 6x9" 200 Watts-Upgrade Replacement Speaker
https://www.retromanufacturing.com/p...ant=7981134403
DVC Speakers
In-Dash Replacement Speakers
Perhaps there are others, but maybe this will help somebody.
Paul Kobres
96' VDP
The following 4 users liked this post by FerrariGuy:
1 of 19 (10-01-2016), al_roethlisberger (10-04-2016), andyXJR (05-21-2017), NTL1991 (10-01-2016)
Old 10-04-2016, 05:13 PM
al_roethlisberger's Avatar
Also, these threads have some info on alternative options for the rear dual-coil 6x9 subwoofer. A search of the X308 forum turns up a lot. Seems like the X308 crowd is working on this issue more than X300 owners, probably because there are lot more X308s out there.
https://www.jaguarforums.com/forum/x...thread-168335/
https://www.jaguarforums.com/forum/x...cement-159588/
And of course, one can easily replace the rotted surround (which is what fails) for about $5-10 as I recall with a kit.
FerrariGuy (05-24-2017)
Old 05-21-2017, 05:54 AM
andyXJR's Avatar
Default Fitting under sub-mesh cover
Ferrariguy - does the speaker you mention fit under the original grill in the rear parcel shelf?
Old 05-24-2017, 02:40 AM
FerrariGuy's Avatar
Although I have not had those speakers in-hand I have to imagine they'd physically fit. The outer perimeter is clearly the same shape and size as the OEM one. Depth would be a concern but I the retro-sound one, at least, is not nearly as deep. There is a fairly thick paper paper ring around the perimeter of the speaker, and is fitted into a plastic spacer that lifts it about 3/4 off the deck. Both of those might need to be replicated on the new speaker which might be *undersized* in some ways.
Another option that *looks* viable is to use a Harman Kardon 6x9 R53 R50 speaker from a mini-cooper. They pop up on ebay and seem to be connected similarly as the Jag speakers:
OEM:
VS:
02-06 mini cooper s R53 R50 left right rear speaker Harman Kardon 65136801095 .. | eBay
doriel
10-11-2016 08:12 PM
biffta
10-04-2016 05:51 AM
Blondie 1
10-01-2016 01:02 PM
Daim
10-01-2016 03:33 AM
Johnken
09-25-2016 01:58 PM
Quick Reply: LNAAAA4144AB Harmon Kardon Rear Subwoofer Theoretical Replacement.
