Looking For Torque Setting Please 96 VDP
Old Jan 6, 2014 | 11:56 AM
vandenplas408's Avatar
Default Looking For Torque Setting Please 96 VDP
I have a 1996 jaguar vanden plas 4.0 Litter and the 7th digit is a 7 in vin
I am going to be replacing
Sway Bar Bushing ( Need torque For 2 bolts on the bracket)
Sway bar Links (Need Torque For top and bottom bolt)
Upper Control Arm Bushing ( Steering Knuckle) ( need torch for 2 bolts Upper)
Lower Control Arm Bushing (Steering Knuckle) ( Ned Torch For 2 Bottom Bolt)
Front Shocks ( Need Torque for top Bolt And Bottom Bolts)
Top Shock Bushing
Lower Shock Bushing
Old Jan 6, 2014 | 12:39 PM
caldercay's Avatar
Top Shock Bushing
Lower Shock Bushing
May i suggest you get the Service Manual via this page:
https://www.jaguarforums.com/forum/x...k-links-20088/
Scroll down till you see the "X300 Service Manuals 95, 96, 97 ..." link, which brings you to a download page. This gets you the Service Manual in PDF format.
Old Jan 6, 2014 | 01:15 PM
i did get the pdf but i can not find the names for the specs i want
can some one help me?
i attached 2 pics of the spec sheet from the pdf
Attached Thumbnails Looking For Torque Setting Please 96 VDP-spec-2.jpg   Looking For Torque Setting Please 96 VDP-spec-1.jpg
Old Jan 6, 2014 | 01:59 PM
AllanG's Avatar
Translation:
Sway bar = stabilizer bar
Control Arm = wishbone
Shock absorber = Damper
You've got the right pages, you should be all set now that you know the names
Old Jan 6, 2014 | 02:11 PM
caldercay's Avatar
Did you check the pages that follow ... diagrams showing the components parts and their "Jag" names?
For example, some manufacturers refer to the sway bar as a stabilizer bar.
Old Jan 6, 2014 | 02:30 PM
Is this right
Sway Bar Bushing ( Need torque For 2 bolts on the bracket) 22-28Nm
Sway bar Links (Need Torque For top and bottom bolt) 52-64Nm
Upper Control Arm Bushing ( Steering Knuckle) 62-78Nm (Fulcrum Bolts)
Lower Control Arm Bushing (Steering Knuckle) 47-63nm (Fulcrum Bolts)
Top nut Shock Bushing 15.5-20.5 nm
Lower Shock Bushing Nut 48-60Nm
Then Im replacing the Upper And Lower Ball Joints
I Need The Torque for the lower ball joints 5 bolt On the bottom of it and the toque for the nut that goes on the ball joint
and for the top i need the 2 bolts toque that hold in it and the torque for the nut that goes on the ball joint
Old Jan 6, 2014 | 05:36 PM
AllanG's Avatar
Yes those are correct.
Ball joint nuts are the first two on the first page 62-78Nm
The lower ball joint set screws are 28-34Nm
The upper Durlock bolts are 70-90Nm
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Neil1664
Jan 20, 2022 08:59 PM
kevinl
Oct 31, 2019 06:15 PM
chatmanx
Sep 11, 2015 07:17 PM
