Low speed clatter from rear
Hi- ‘96 XJ12 has a clatter at low speeds, from the rear, especially when turning. This XJ12 is just on the road after major suspension work (all bushings and mounts up front, new shocks and foam bits all around) new carrier bearing, driveshaft u joints, transmission mount. You can hear the clatter plainly around 15-16 seconds into this 30 second you tube video. So what do I throw parts at next?
The sound is like a low rumble
Cheaper things is like a muffler mount rattle and some other things that may have been disturbed in the last section 19 of the TBS table
JagRepair.com - Jaguar Repair Information Resource
The turning is a clue of putting a mechanical load on one side , does it accure on both turn directions ?
Parker your suggestion of TSB 19 was a fantastic and well educated guess! Without even putting the car back on the lift I will say with 99% certainty you a correct. I did not even vaguely attempt to set the parking brake cable when I put this car together. I just put enough tension on that it wouldn’t fall apart. I will set the parking brake cable ASAP.
The parking brake , if that , is an interesting bit of kit that others have gone through except myself
Exhaust hangers ?
There should be some info in the large manual I split up and posted as 5 parts in post # 4 in the link below
I'm sure others have some info on freeing things up as I have seen a couple of post in the past
Section 12 . 1 . 7 of the 3rd partition pages 201 - 300
Repair Manual - Jaguar Forums - Jaguar Enthusiasts Forum
Exhaust hangers ?
Quadcammer
Nov 23, 2023 09:15 AM
