mixed answers
Old Feb 25, 2009 | 10:01 AM
toutlnone's Avatar
Default mixed answers
Getting mixed answers on my 96 xj6 rotors with or without hub.Ordered new rotors and they came rotors only. all data says there are disc screws, but mine have none.My question is were some produced with hubs attached to the rotors.Moore Jaguar in St louis missouri parts man swears they are seperate.
Old Feb 25, 2009 | 10:07 AM
JagtechOhio's Avatar
Jaguar never sold a hub and rotor together, they were always separate items. The countersunk screws are superfluous, as the lugnuts secure the wheel and rotor to the hub. I think the screws were deleted after '94 but it's a trivial point. Some of the rotors you can buy may still have a countersunk hole drilled in them regardless. Jaguar hubs are generally $300 each, so it's a blessing that they are separate.
Old Feb 25, 2009 | 10:27 AM
toutlnone's Avatar
Thumbs up
Thanks for your expertise. Any ideas as how to loosen the disc from the hub with out hitting it with the sledge hammer?
Old Feb 25, 2009 | 10:39 AM
whiteSTR's Avatar
Rubber mallet if your worried, but the rotors are pretty tough, your not going to hurt them or anything else on the suspension unless you have terrible hand-eye coordination .. Eric
Old Feb 25, 2009 | 11:00 AM
I have a kick *** heat gun that I use for alot of stuff that would otherwise require a torch. Clean the mating seam with a wire brush, soak in some penetrant, and heat or beat. They can be really stuck, and a severe pounding can't be real good for the wheel bearings.
oldjaglover
Dec 25, 2024 04:33 PM
Tipptone
Oct 6, 2015 11:32 AM
baskervillema
Oct 1, 2015 06:43 PM
Johnken
Oct 1, 2015 05:07 PM
sdelliott58
Oct 1, 2015 01:46 AM
