Need female connector for CK position sensor
Old Jun 16, 2016 | 10:36 PM
dmpsqrd's Avatar
Default Need female connector for CK position sensor
I am looking for the female receiving connector that accepts the male end of the crankshaft position sensor. Any leads or sources would be greatly appreciated. The only one I've found is $125...used...
Old Jun 17, 2016 | 05:10 AM
aholbro1's Avatar
Recently while grabbing a cam cover at the local Pick n Pull, I thought a spare CKPS may com in handy.... and since I broke the locking tab on my first Andy bracket install, I just clipped the wire about 3" back after unbolting it. Sensor and all for $9-$13; can't remember exactly. Get the Row52" app and set up alerts - I seem to recall a PnP or two in the Chicago area.
Old Jun 17, 2016 | 05:54 AM
OR, use one of these.
Quick Connect - Products - Narva
Old Jun 17, 2016 | 06:49 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
From memory the connector is likley to be from the AMP econoseal range.
If you look at the electrical section of the service manual near the start there is a Connectors section that has illustrations of the different connectors that are used. Econseal connectors should be widely available at low cost. You can even buy the individual connector blades and small rubber plug seals where the cables enter the plug body.
Old Jun 20, 2016 | 06:33 AM
V126man's Avatar
Default Amp selaed connector catalogue
Amp sealed connector catalogue attached
File Type: pdf
scubayachts
Oct 27, 2018 10:47 AM
MalnFaye
Jun 24, 2016 04:08 PM
Uncle Fishbits
US Western
Jun 17, 2016 02:20 PM
Oceansidesurf
Jun 9, 2016 02:58 AM
xtype62
May 18, 2016 12:37 PM
