need help 1997 xj6l ac
Old Sep 30, 2012 | 01:28 PM
taylorxj6's Avatar
Default need help 1997 xj6l ac
ok so my ac only.blows real cold.when im at a stop them when driving it warms up i know i need to replace the ac fan relay but i don't see that being the problem since kt does opposite of what the fan problem would cause it to do any help please
Old Sep 30, 2012 | 02:13 PM
taylorxj6's Avatar
Anybody please
Old Sep 30, 2012 | 02:36 PM
steven300's Avatar
i don't know if this will help much,but here go'es.there are a series of blend doors that operate defrost,floor and dash outlets.on most of the cars i've worked on they are vacuum controled,if that is the case you have a vacuum problem.ether a hose leak or a bad blend door.however this car could have electricly controlled blend doors,in which case i was of little help.good luck...steve.
Old Sep 30, 2012 | 03:23 PM
taylorxj6's Avatar
How would i test to see of i have a vacuum leak
DevonDavid
Jan 8, 2026 03:12 PM
JungleJonny
Oct 5, 2015 03:52 PM
speacock
Oct 3, 2015 11:15 AM
42Ajd
Sep 26, 2015 07:04 PM
