Hi,
My car has sat for about 4 days and now will not start. My brake lights are working and the P is lit up. However when I hit my brakes I do not hear the shifter solenoid releasing my shifter. I removed the star screw, moved my shifter to neutral and still nothing when I turn the key. Everything looks fine as I turn the key except for the start position.
Please let me know what I should be looking for.
Thanks,
Jomo
I park in a basement garage, along with other vehicles, and sometimes I have the same problem and the solution is exactly as you used, lock and unlock using the remote.
I think the problem must be interference with the car's security module caused by other owners using their remotes on their cars and the lock/unlock resets it.
