What’s this brown wire for in the trunk?
There was some sort of diode for shipping the car and was removed by the dealer
I can be wrong
I saw it somewhere in a document
I think a diode was attached to the battery positive post
Can you tell the other attach point ?
I can be wrong
It goes all the way to the passage side ?
See page 32 lower left corner of page
Any hint that it is brown / black stripe wire ?
The wire in question may not be a accurate color code as this wire is a by the way , put this in there
Motorcarman ( Bob ) would know more about this
The BT4 connector pin 22 is above the fuel tank behind the large baggage compartment panel
Avoid disconnecting this connector as there are problems getting it back together
jagxj1996.pdf (jagrepair.com)
