What’s this brown wire for in the trunk?
Old Oct 23, 2021 | 11:04 AM
95x300's Avatar
Default What’s this brown wire for in the trunk?
It’s just hanging out there in the luggage compartment fuse box
Old Oct 23, 2021 | 11:06 AM
Parker 7's Avatar
There was some sort of diode for shipping the car and was removed by the dealer
I can be wrong
I saw it somewhere in a document
I think a diode was attached to the battery positive post
Can you tell the other attach point ?
Old Oct 23, 2021 | 08:37 PM
95x300's Avatar
I can be wrong
It goes all the way to the passage side ?
Old Oct 23, 2021 | 08:38 PM
95x300's Avatar
My truck release button is not working..not sure if that’s the reason?
Old Oct 29, 2021 | 01:27 AM
Parker 7's Avatar
See page 32 lower left corner of page
Any hint that it is brown / black stripe wire ?
The wire in question may not be a accurate color code as this wire is a by the way , put this in there
Motorcarman ( Bob ) would know more about this
The BT4 connector pin 22 is above the fuel tank behind the large baggage compartment panel
Avoid disconnecting this connector as there are problems getting it back together
jagxj1996.pdf (jagrepair.com)
95x300
Oct 23, 2021 11:01 AM
dannerbo
Oct 13, 2021 06:32 PM
lair12
I-Pace EV
Apr 5, 2020 05:00 PM
Dlo3575
Jul 27, 2019 03:53 PM
themachine
Dec 26, 2017 10:40 PM
