No side mirror control/Driver Window/Seat control
Old Jul 8, 2014 | 08:42 AM
AlbBolivar's Avatar
Default No side mirror control/Driver Window/Seat control
Hey guys,
for some reason, yesterday some of my drivers side controls stopped working. Not sure if it's all related but my two side mirrors no longer adjust via the joystick on the master switch. Drivers window doesn't go up or down and also my drivers seat no longer adjust.
Not exactly sure what could be causing these issues
Old Jul 8, 2014 | 08:45 AM
jimbov8's Avatar
Check the fuses first but I'm guessing you need to look at the wiring loom under the drivers seat for any breaks or signs of chaffing.
Then try disconnecting the drivers side module, under the seat, clean the connectors and pins, reconnect and try again.
Hope this helps,
Old Jul 8, 2014 | 11:00 AM
AlbBolivar's Avatar
Oh man. With all the problems I've been trying to sort out with this xjr since ice picked it up I totally forgot to check the simple things first.
It ended up being a blown f6 5amp fuse in the drivers side rear passenger kick board.
Thanks for the help!
Old Jul 8, 2014 | 11:10 AM
jimbov8's Avatar
Glad to hear you are sorted. Sometimes we all forget to check the simple things first
Old Jul 9, 2014 | 03:18 PM
al_roethlisberger's Avatar
Wonder what blew the fuse though. If it blows again, may need to find a short
Old Jul 9, 2014 | 04:00 PM
AlbBolivar's Avatar
It was the 5amp fuse which is f6 underneath the backseat drivers side kick board
kevinl
Oct 31, 2019 06:15 PM
Razor
Aug 28, 2019 08:34 PM
motorhead69
Sep 9, 2015 10:04 AM
tberg
Sep 7, 2015 07:32 AM
jaguarbill
Sep 5, 2015 11:43 AM
