Not sure what the actual term of this part is..please help
Old Jan 21, 2011 | 09:10 PM
SRL1990's Avatar
Default Not sure what the actual term of this part is..please help
Need help finding one. The plastic pieces snapped off due to audio installment. Has anyone fixed or ever found a replacement for it? It becomes loose and goes out of place whenever I shift from Drive to Park.
Old Jan 22, 2011 | 03:54 AM
Cadillac's Avatar
I believe it's called shift bezel
Old Jan 22, 2011 | 07:59 AM
aholbro1's Avatar
I like shift bezel better...but have found both "selector chrome and leather trim finisher" and "gear lever surround finisher" in the service manual.
Mine also "floats" but looking at the broken tabs and the amount of movement when actuating the shift lever, I'm not persuaded a replacement would last all that long either. Think I'll live with mine, tho one must occasionally bump it to remove the keys!
Old Jan 22, 2011 | 11:23 AM
SRL1990's Avatar
Thanks again for the help.
Old Jan 22, 2011 | 01:30 PM
Fenja's Avatar
Mine is cracked and wobbly too. I think that and the cup holder are the only two major disappointments I have.
Old Jan 22, 2011 | 01:36 PM
aholbro1's Avatar
lol! Cupholder merely misnamed....more of a cup-rest or cup-locator....works good as long as I hold on to the cup whilst it's in the cupholder!
SR, please keep us updated if you find a replacement source and it holds up better than the original
Old Jan 24, 2011 | 02:30 PM
SRL1990's Avatar
Default hey
I found a replacement for the bezel...EBAY 40$..I don't feel like paying that..I took out the chrome trim inside the bezel and just placed the leather trim in its place..I sorta jammed it in so it doesn't move..for the Cup Holder I got rid of the spring inside the holder tray (that makes the holders keep popping)..Once I got rid of the spring the cup holders stayed in place. I don't use the holders and don't ever wanna use them lol they are a nightmare. I also got them tanned to match the steering wheel
http://www.youtube.com/watch?v=KppoksZTEO4 This video was before i fixed it.
Old Sep 11, 2012 | 04:58 PM
bliving7's Avatar
Hi,
I have used with success some fine fiberglass tape as used in building R/C airplanes with a cement to repair some of the crappy Jag plastic parts. For plastic the cement of choice is CA. And the plastic needs to be roughened up.
I repaired the chrome bezel piece you mention using that. One part was missing and I replaced it with a cut piece of popsicle stick. But anything would probably do.
bliving7
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
Jaguar Forums Editor
Jaguar Press release
Sep 4, 2015 09:18 AM
Sep 3, 2015 09:38 AM
TC Johnson
Sep 2, 2015 09:30 AM
