Octopus hoses
Old Apr 27, 2024 | 07:14 PM
epreusser's Avatar
Default Octopus hoses
I am finishing up the dreaded octopus hoses on my '96 XJR. Unfortuately, I did not take enough pictures. does anyone have a diagram or picture showing where all the hoses go? There is a vac hose with a rubber 90 degree fitting that goes over the supercharger but to where? Also a vac line that comes from the firewal/down to another group of hoses lower down, where does hte other end go? Under the 90 degree hose there is two other fittings, does the small octopus hose go on the fitting under the 90 or the one even lower? Also seem to have lost the nut/bolt that hold the long slide fitting that goes the vac thing near the throttle bracket. HELP PLEASE!
Ed
Old Apr 28, 2024 | 02:35 AM
John Herbert's Avatar
See the bottom right diagram on the attached, it shows the connections.
John Herbert
1996 XJR
File Type: pdf
Old Apr 29, 2024 | 06:24 AM
Spud Maat's Avatar
on the note of octopus hoses.
has anyone tried these silicone hoses?
i need to change my hose at some point soon it has slow leak but i have been putting off doing it.
i am tempted by this silicone hose as it should last forever and might be easier to install as its more flexible.
however,
it is a brand i have never heard of and is on ALI Express so yeah....
i mean i have never had an issue with anything from ALI Express before but i just always expect that the quality is questionable.
https://www.aliexpress.com/item/1005...martRedirect=y
Old Apr 30, 2024 | 12:36 AM
Suggest you do some Google research on silicone hoses for auto use.
It seems they have a greater permeation rate than the usual rubber hoses, ok for race use but not recommended for street use.
John Herbert
1996 XJR
Old May 11, 2024 | 08:32 AM
Spud Maat's Avatar
question regarding these hoses and the availability.
as I look around online I pretty much see the hose supplied by URO.
how do these seem to hold up?
are there higher quality ones available by dunlop or anything?
would like to replace it with one that will holdup for as long as possible.
Old May 11, 2024 | 09:07 AM
Doug's Avatar
Sometimes Rock Auto has listings for Gates and Dayco hoses for our oldie Jags.
Stosh1017
Nov 1, 2023 03:05 PM
Shoreguy
Mar 20, 2020 08:44 PM
mrplow58
May 14, 2016 03:38 PM
Lubrication
Aug 17, 2015 01:39 AM
brgjag
Oct 5, 2014 04:34 PM
