Oh no the bolt is now stripped *help me*
Old Jan 7, 2014 | 06:12 PM
vandenplas408's Avatar
Default Oh no the bolt is now stripped *help me*
I was removing the stabilizer links
The long bottom bolt came out really nice and the nut threads 0n perfect
The Top WAS A NIGHTMARE??
coming out the bolt seem to angle weird. when i finally got it out
2 of the threads on the bolt were completely GONE!!!
Inside the nut i notice 1 thread has a chunk missing
Im trying to replace the stabilizer links but what can i do with the bolt?
I cant drive my car with out the link right?????
Should i attempt a Lows or Home depot Replacement bolt and nut?
or is there a place to order the exact bolt?
should i just get a lows or home depot bolt and go to junk yard after and steal an old one?
I NEED TO FIX THIS TONIGHT ITS MY ONLY CAR!!THAT RUNS
I WORK TOMORROW
Old Jan 7, 2014 | 06:26 PM
caldercay's Avatar
I NEED TO FIX THIS TONIGHT ITS MY ONLY CAR!! I WORK TOMORROW
Well, if you need the car ready by tonight, I'd say a trip to Lowe's or Home Depot is in order, provided you get a bolt\nut with the proper grade to match original.
Old Jan 7, 2014 | 06:29 PM
is there a place i can order one or two online?
i would get a low or hd bolt for a temp...
how do i tell the proper grade?
Old Jan 7, 2014 | 06:34 PM
On the Bolt It Says
Atlas
S
Old Jan 7, 2014 | 06:50 PM
caldercay's Avatar
On the Bolt It Says
Atlas
S
Bolt grade guide:
Bolt Depot - Bolt Grade Markings and Strength Chart
Old Jan 7, 2014 | 06:53 PM
AllanG's Avatar
No need to panic
The bolt is a 7/16" x 2 3/16" shoulder bolt. You should be able to pick them up at a local hardware store. It won't matter if the bolt is a tad longer say 2 1/4"
Get a 7/16" nylon insert nut and a washer.
Look for grade 8 steel
Old Jan 7, 2014 | 06:54 PM
Grade 5
thanks
Old Jan 7, 2014 | 07:01 PM
AllanG's Avatar
You can certainly use grade 5 but for suspension systems I always try to get grade 8 hardware, it's much stronger and those bolts take a beating, especially when the bushings fail!!
Old Jan 7, 2014 | 07:02 PM
Originally Posted by AllanG
No need to panic
thanks a lot mate
im gonna buy 2 so both sides are exactly the same.
ill save the other one if its good and find my exact yr/model
if not i can swoop some from the junk yard but what yr/model
have these same bolts as well?
Old Jan 7, 2014 | 07:07 PM
AllanG's Avatar
thanks a lot mate
It's a basic nut and bolt, no need to try and find one in the breakers yard, in fact the last thing you'd want to do is replace it with an old one. Nuts and bolts are cheap
Old Jan 7, 2014 | 10:29 PM
yah thats true no need junk bolts
they did not have the exact bolt 7/16 "-20 x 2 3/16"
they had a 7/16"-20 x 2 1/2
its a bit longer but it worked
i think ill just order that exact bolt size online and replace again since its super easy. i just think they made it that size for a reason?
thanks for your help AllanG Saved the night
Old Jan 8, 2014 | 05:35 AM
RJ237's Avatar
My XJ6 is all metric, this is interesting that others are fractional.
Old Jan 8, 2014 | 05:54 AM
AllanG's Avatar
RJ,
Yes most of the car is metric but I think you'll find those bolts and certain others are imperial.
Old Jan 8, 2014 | 09:28 AM
i can not seem to find anything online either
close i found was
7/16-20 X 2-1/4 Fine Thread Hex Head Bolt Grade 5 UNF Zinc 25 Pack
pack of 25 for $19
Old Jan 8, 2014 | 11:16 AM
n_sweeney's Avatar
close i found was
pack of 25 for $19
You can try this:
McMaster-Carr
Old Jan 8, 2014 | 01:44 PM
mgb4tim's Avatar
Sorry to say, the big boxes most likely won't have that. Find a true hardware store.
No need to panic
Old Jan 8, 2014 | 01:46 PM
AllanG's Avatar
Originally Posted by n_sweeney
You can try this:
McMaster-Carr
Yep as I said you will probably find it in 2 1/4" length. The length is immaterial provided it is long enough and not too long to could on anything. 1/16" will be of no consequence.
Old Jan 8, 2014 | 01:52 PM
AllanG's Avatar
My local Lowes has them Shop The Hillman Group 50-Count 7/16-in-20 x 2-1/4-in Yellow Zinc Standard (SAE) Hex Bolts at Lowes.com
Mac Allan
Jul 20, 2020 05:46 PM
04Xjrsteve
May 7, 2019 04:06 PM
Johnken
Apr 8, 2018 10:21 AM
Johncy2000
Oct 2, 2015 01:05 AM
