oil pressure gauge
Old Feb 24, 2009 | 09:49 AM
mtotrainer's Avatar
Default oil pressure gauge
can any-one tell me why my gauge just dropped to zero pressure and the oil light came on,but the oil was full and the motor didn,t heat up so I kept going and after 100 miles the gauge came back to normal pressure.It did this 3 times over 200 miles.The engine never made any noises or dropped power at all...Thx Jamie
Old Feb 24, 2009 | 09:53 AM
Doug's Avatar
My guess is that the sending unit is on its way out....
Old Feb 24, 2009 | 12:32 PM
cool's Avatar
check oil pump pressure, its quite common on this series (X300). Can also be a cost of pre mature wear on your engine internal parts.
Old Feb 25, 2009 | 06:07 AM
mtotrainer's Avatar
could you tell me where the sending unit is found? Also ...any idea of the cost? Thanks again . Jamie
Old Feb 27, 2009 | 11:35 AM
cool's Avatar
the gauge measures the pressure and flow of the oil circulating within the engine system, if the gauges and sending unit are in proper working condition then it is necessary to check the flow system, there might be some restrictions either on the oil filter, oil tube and or oil pump this is a serious and a sign/clue to clean the system, it can cause premature wear on the engines internal component.
Old Mar 5, 2009 | 09:18 AM
panchostatus's Avatar
check the pressure with a wet gauge to verify correct oil pressure, and this will definitely indicate a faulty sending unit. The sending unit on my '95 XJR had gone completely bad, and the gauge on the dash is pegged on high all the time. The results I got when I did the test were at about 55 psi on cold start and around 30-35 psi when the engine warmed up, which is normal. not sure if it's the same on the supercharged engines, but I hope this helps.
Old Mar 5, 2009 | 10:38 PM
dougs02's Avatar
On a 95 XJ6 I had, A Jaguar service rep told me that Jaguars do not have an oil pressure problem, but oil pressure sensors do fail. They replaced mine with one of Ford's "better Ideas". It's a sender that turns your gauge into an idiot gauge. As soon as the engine starts and you have oil pressure it shows about 40-45 psi and never moves from that. I did not even get out of the dealer parking before I discovered that they replaced my oil pressure sensor with a sender. I hit up the service rep about that and he stated Jaguar no longer services sensors because of the failure rate. That's the type of sender that my old 69 Ford pickup had.
Doug
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
ccfulton
Sep 20, 2015 05:15 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
