Oil Pressure Sending Unit location?
Old Feb 4, 2022 | 04:36 PM
baws's Avatar
Default Oil Pressure Sending Unit location?
Where on the 4 liter engine in an XJ6, is the sending unit for the oil pressure located?
And where is the best place to get a new one?
Thanks!
Old Feb 5, 2022 | 07:37 AM
Mkii250's Avatar
It's on the block right beside the oil filter (immediately rearward of the filter). Rockauto.com has a few to choose from starting around $40.
If you are replacing the original (which showed actual oil pressure) you'll find that the new sending unit does not do that. It's a dummy unit that just shows that there IS pressure, and it may read high unless you also install an inline 75ohm 0.5W resistor (which brings the needle to the middle of the gauge). I don't know a way around this.
Old Feb 5, 2022 | 08:27 AM
motorcarman's Avatar
This is the info we got when I worked at the dealer.
Old Feb 5, 2022 | 01:41 PM
baws's Avatar
Thanks guys!
iramphal
May 25, 2018 08:33 AM
ahunt4
Feb 7, 2015 02:23 PM
f-cano
Apr 23, 2012 11:25 AM
dperry
May 20, 2010 05:28 PM
manderson10
Jan 3, 2009 08:07 AM
