P1607 Code on 95 XJS
Old Jun 30, 2016 | 08:22 PM
marmar1305's Avatar
Default P1607 Code on 95 XJS
Hi, When I drive my XJS in very slow busy traffic during hot weather the engine suddenly stalls, check engine light pops up and when I scan the OBD the following code shows:
P1607 MIL O/P Circuit Malfunction.
Can anybody tells me what this means and what to do please?
Thanks,
Marc
Old Jul 2, 2016 | 08:34 AM
RJ237's Avatar
What engine? This is not the XJS forum, but if you have a six someone may be able to help.
Old Jul 3, 2016 | 02:25 PM
marmar1305's Avatar
Thanks for your reply. Yes I have a 4.0L 6cyl engine.
Old Jul 3, 2016 | 02:42 PM
marmar1305's Avatar
I would appreciate if you could tell me which forum to use ... I don`t see the proper one.
Old Jul 3, 2016 | 04:22 PM
RJ237's Avatar
There are not many XJS sixes. If it's the last version with the AJ16 engine you may find help here. Below is the link to the XJS forum.
XJS ( X27 ) - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jul 3, 2016 | 04:31 PM
RJ237's Avatar
I think the code may relate to the ECU. You may want to disconnect it and clean the connections with contact cleaner and inspect for corrosion. First disconnect the negative battery cable.
Also do a search on both forums with the subject engine stalls to see what others may have found.
Jack Mathews
General Tech Help
May 28, 2016 11:34 AM
mrplow58
Apr 11, 2016 04:19 PM
dartech
Apr 9, 2016 09:28 AM
newenglandxj8
Apr 7, 2016 10:34 AM
vinny jones
Apr 5, 2016 01:57 AM
