Please help asap
Old Jan 26, 2012 | 10:12 AM
jhxj6's Avatar
yes, before all this the fans functioned properly. Also got my codes read this morning and I'm getting P0300 and P0304. just replaced all spark plugs and coils 5 and 6 so I don't understand. Getting P1313 which is a "lean surge"??
What's a lean surge?
Old Jan 26, 2012 | 10:38 AM
xjrguy's Avatar
Well, your code translation isn't exactly correct. P1313 is for a misfire count severe enough to cause catalyst damage on cylinders 1, 2 and 3. Meaning greater than 30% in 200 revolutions. P0304 is a misfire count on cylinder #4 exceeding 3% in 1000 revs.
Cheers,
Old Jan 26, 2012 | 11:02 AM
jhxj6's Avatar
I just did the modification and STILL no action from the fans.
xjrguy, what could be causing that to happen?
Old Jan 26, 2012 | 11:21 AM
xjrguy's Avatar
Now you have to check the fans themselves and get a look at the relay module below the LH headlamps. For low speed the fans are powered in series, one after the other, for high speed the relay module switches them both to parallel. They run at full speed then. If one fan is open circuit, neither will run at low speed.
So low speed they run on six volts each, twelve volts on high.
Good luck!
Old Jan 26, 2012 | 11:28 AM
jhxj6's Avatar
Thank you i'll order the relay and post again.
Do you have any idea on what could be causing the misfire?
Old Feb 3, 2012 | 01:44 PM
jhxj6's Avatar
replaced the relay today with the new one mortorcartsltd sent me.
Still nothing.
Is the modification correct?
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
Collector1
Sep 26, 2015 05:28 PM
European_Auto11558
Sep 25, 2015 08:05 PM
MrMellor
Sep 21, 2015 10:10 PM
