Post purchase service
Old Apr 8, 2015 | 02:48 PM
Clasico's Avatar
Default Post purchase service
Hi there, I'm picking my "new" 20 years old X300 4.0 Sovereign tomorrow and have already booked an indy service to include:
- all fluids and filters including gearbox and diff oil
- new plugs
- OBD diagnosis just in case
I'm on a budget but is there anything else I should be checking as well?
Your expert advice will be highly appreciated.
I include a view to the engine bay, sorry is upside down for no good reason!
Old Apr 8, 2015 | 05:46 PM
Scarecrow's Avatar
Congratulations on the pickup. Engine bay looks clean. Let's see some more pictures of that beauty!
I did everything you mentioned as well as replaced the wheel bearings. I replaced them because I wanted to start fresh. If they are still good I would just have them repacked with new grease. I also changed the thermostat, but that is mainly because I had to replace the radiator and decided to change the thermostat also.
Enjoy your new ride.
Old Apr 8, 2015 | 06:44 PM
RJ237's Avatar
The thermostat is a good idea. They have a record of sticking open after a few years.
Old Apr 21, 2015 | 08:05 AM
Clasico's Avatar
Gone to check Fritz (the cat) with an specialised indie (he even has one himself) and the veredict is:
You've got a good one mate!!!
Here it goes the service list though,
- change ALL fluid and fiters. Check ac gas too
- replace thermostat and chech waterpump hoses connections
- change trapezoidal bands
- solder tiny crack on exhaust downpipes
- radiator bushes
- clean servodirection pump and put missing boot back
- grease usual points and wheel bearings
- new cam gasket
- check differential leak, put new gasket
- plugs if needed
Hope this list could be of some help to newbies like me.
Let me know if you feel I'm missing something
Old Apr 21, 2015 | 07:54 PM
aholbro1's Avatar
Check/replace condenser bushes as long as you are doing the radiator. Lowers are likely missing anyway. Flush heater core while you are doing the thermostat.
Shawn Svacha
Nov 4, 2019 02:47 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
OkieTim
Sep 2, 2015 12:48 PM
