Power Steering Hose to Cooler
Old Nov 27, 2019 | 09:36 AM
EZDriver's Avatar
Smile Power Steering Hose to Cooler
My power steering return hose to cooler has started to leak red stuff on my 95 XJ6. I replaced the pressure hose several years ago due to leakage and big mess. Now the other hose has started to leak also. So far I have been unable to locate a new replacement. They either are out of stock or they just don't stock that low pressure hose. I looked at Parts Geek, Land Rove Auto Parts, Rock Auto and EBay.
Any suggestions would be appreciated.
Thanks Guys
Old Nov 27, 2019 | 10:55 AM
b1mcp's Avatar
It's available from Jaguar Classic Parts (but not cheap).
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Nov 28, 2019 | 01:40 AM
Peter RM's Avatar
MNA3990AC?
I'd try cutting the old ferrule off with an angle grinder and then replace it with a hose clamp that you can tighten. Much better than paying this:
https://www.ebay.com.au/itm/New-Jagu...4AAOSwCtJcc4Pk
You could also get a hose service place to replace the hose on the old fitting if you don't like the look of a hose clamp
Old Nov 28, 2019 | 06:31 PM
EZDriver's Avatar
Thanks for the input. I have looked closely at this diagram they present. And frankly I don't think that part (#20) looks like the same part that I have. So I'm still looking.
Old Dec 4, 2019 | 09:16 PM
Danielle Comer's Avatar
Thanks Guys
https://www.google.com/shopping/prod...003609464,cs:1
Old Dec 5, 2019 | 10:18 AM
juha_teuvonnen's Avatar
For $41 I would not bother fabricating anything.
The aluminum (or steel) part of the hose is rarely if ever the problem. You can get a repair ferrule and replace the rubber hose part. Any shop that does custom hydraulic hoses can do it for you. When I am too lazy to do it myself I pay short money to have it done.
In the past I have successfully replaced various poorly designed and long discontinued hoses with adapters to AN fittings and AN hoses. In my experience quality AN hoses work better and are more durable than the factory ones. If an off-the-shelf adapter to AN is not available, I make one on a lathe. I requires rudimentary machinist skills at best and even the cheapest, abundantly available hobbyist-level lathe will do the trick.
Nescafe
Mar 12, 2018 02:49 AM
JonLee
Aug 2, 2017 08:06 AM
hoodun
Jun 2, 2015 12:53 AM
mohavewolfpup
XJ40 ( XJ81 )
Feb 28, 2015 10:57 AM
solerydr
Jun 27, 2014 10:04 AM
