Power Steering Issues
Old Apr 19, 2023 | 07:05 PM
Okami's Avatar
Default Power Steering Issues
I am becoming more and more puzzled by my X300 and could use some help diagnosing.
The powersteering is non-existent at idle/stopped.
I can hear the brown relay under the passenger side clicking when the car is running and power steering called upon(don't ask me when in that process it has been a moment).
I just got done rebuilding the power steering pump with no success, but nothing looked bad in the unit as I pulled it apart.
The high pressure hose has been replaced and it doesn't seem like there are any other leaks.
The inside of the rack boots were dry last time I checked.
A friend mentioned a servotronic relay in the car that I can't seem to find.
What do I look at next, I am open to anything.
Old Apr 19, 2023 | 07:37 PM
Parker 7's Avatar
See page 19
THE VARIABLE SPEED MODULE WILL BE AHEAD OF RELAY # 2 WHICH IF GOT GOLD PLATED FRONT WINDSHEILD HEAT LIKE ON AIRCRAFT AND IS NOT FOUND ON MOST EXAMPLES
Something about a volvo module works
X300 1996 LWB.pdf (jagrepair.com)
There should be a fuse involved
MrVette
E type ( XK-E )
Mar 3, 2024 10:22 AM
Muz52
Mark V - X 420G
Aug 22, 2017 05:09 PM
rhofatl
Apr 21, 2017 12:18 PM
devanwon
Nov 11, 2008 09:05 PM
