Power Steering leak
Old Feb 10, 2024 | 01:35 PM
PBoudr's Avatar
Default Power Steering leak
My ‘97 vdp had a small power steering leak but recently it got worse. I took a photo of where it’s coming from. I was hoping maybe a hose but it looks like that’s not the case.
Old Feb 10, 2024 | 02:56 PM
Parker 7's Avatar
From the bottom of the reservoir where the 2 lines clamp , the hoses distort from the age and leak going everywhere.
Cut an inch off the hoses for new clamp / hose material
If the leak is coming from the steering rack you can do a drain refresh cycle 4 or 5 times to get fresh power steering fluid to rejuvenate the seals
It is a ZF 7852 series but I don't know about the last numbers as someone recently took a pic of their's
See attached file below
File Type: pdf
Old Feb 10, 2024 | 03:35 PM
PBoudr's Avatar
I actually added AT-205 leak sealer last week hoping it would help but that’s when it got worse. After reading a couple of threads on here I was contemplating buying a generic hose hit the low side and replacing that. But when I looked under and saw that drip I assumed that maybe it was coming from somewhere else.
Old Feb 10, 2024 | 03:44 PM
Parker 7's Avatar
Is it dry above the rack ?
Old Feb 10, 2024 | 04:43 PM
Parker 7's Avatar
In theory you can change the outer most gland nut seal ( without removing the rack ) as your open boot may have let dirt in to effect the seal
Someone ( 944play ) with the V - 12 went through sourcing the proper boots if yours can't be salvaged
Steering rack boots, ÜRO JLM11688 do not fit - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 10, 2024 | 05:44 PM
PBoudr's Avatar
Yeah it's seems dry up top. It was pretty gunked up but i wiped down the hoses and their doesn't appear to be a fresh leak from the reservoir hoses. I took a closer look at the boot and there's a good amount of fluid in there. So it does appear that is the source of the leak. There's a couple of good youtube videos on rebuilding them so I'll have to check that out. Thanks again for your input.
Old Feb 10, 2024 | 05:57 PM
Parker 7's Avatar
You can clear the boot and see if it fills back up after correcting the under reservoir
gogobrent
Feb 12, 2024 11:24 AM
DoccyG
May 26, 2023 10:40 AM
JagYi
May 19, 2023 02:20 PM
Daddygram
XJ40 ( XJ81 )
Dec 30, 2021 06:37 AM
jaguarrick1
Jun 26, 2020 03:47 PM
