power steering problem
Old Jan 1, 2009 | 08:37 AM
steffenvh's Avatar
Default power steering problem
hello,
I have a problem with my power steerign of my x300 xjr6; when the engine is cold the power steering works well and easy but when the car warms up the power steering is very hard. fluid level is FULL.
Steffen
Old Jan 5, 2009 | 04:12 PM
ken@britishparts.com's Avatar
Default RE: power steering problem
As a guess, perhaps the p/s pump is getting weak. Maybe as the fluid heats and thins, the pump is weak and having trouble pushing it??? Just a guess. I can't really think of any other plausible reasons...and this seems kind of a goofy guess.
Old Jan 6, 2009 | 11:18 PM
cool's Avatar
The reason for hardening of steering as the fluid heat goes up is due to the rack and pinion and fluid cooling condition. Try also changing the whole fluid including those inside the rack with a higher grade power steering fluid.
Old Jan 6, 2009 | 11:42 PM
Doug's Avatar
Couldn't hurt to replace the fluid and bleed the system. The correct flluid is Dexron III....not sure what Cool had in mind for an upgrade.
There's always the posibility of an electrical malfunction. The steering control module takes a vehicle speed reading from the instrument cluster (which gets its reading from the left rear wheel sensor) and adjusts the assist according the road speed. Maybe, just maybe, you have a module problem? <shrug> Sometimes solid state module act up when they get warm.
Not much help, I know.
If you have a shop manual I'm sure there are some circuit tests ......
Sorry
Old Jan 8, 2009 | 02:16 PM
cool's Avatar
If in case it is indeed steering speed control module it is located on the lower A pillar left driver side (US) take out the plastic cover and you will see and have a full access to the servo module which controls the stiffness due to speed reading. You can try to test it by using an ohm meter to see if the reading kicks up every time you turn the steering even at a stand still, another possibility is you might have to purge the system if in case you have opened up the system before.
by the way when i mention upgrade of fluid i meant changing it if it was not the correct grade.
Old Jul 31, 2009 | 02:34 AM
steffenvh's Avatar
Hello cemreis,
I have still the same problem, when the car is cold, the power steering works fine, but after a couple of minutes, the power steering works very hard.
I've changed the whole fluid with dexron 3 and still the same problem.
The question is, how can i kwow if it's the power steering pump, or the steering box/rack?
Many thanks
Steffen
Old Aug 4, 2009 | 12:41 PM
steffenvh's Avatar
thanky you!
i Noticed, when the power steering goed very hard when the engine is warm, that when i push the accelator a little bit (around 1500 rpm) that the power steering works a litlle bit more easier, but not 100%
Where is that valve located, where you talked about?
Steffen
Old Aug 4, 2009 | 01:45 PM
JagtechOhio's Avatar
Bad pump, Cool is right about testing and eliminating the servotronic assist as a possible cause. Disabling it doesn't make the kind of change to steering effort you are talking about.
A bad rebuilt pump causes the same symptoms as a bad pump. A good pump will fix the car.
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
sogood
Sep 15, 2015 07:35 AM
jehart49
Sep 12, 2015 05:36 PM
