Question about lug nuts on 96 x300, please help.
Old Apr 14, 2010 | 06:33 AM
Rocafella117's Avatar
Default Question about lug nuts on 96 x300, please help.
hello, about a year ago I purchased original jaguar 16" rims that were chrome plated from LA Tire online, they spealize in adding chrome plating to regular factory rims on cars. Now, the factory lug nuts for my 1996 XJ6 do fit in there, but everytime I need to have them removed for a tire rotation or balance I have a lot of porblems getting them off, as they do get stuck in there rim quite often. Is there any other type of aftermket or jaguar lug nuts that would fit? I see a lot of lug nuts for the car on ebay for a cheap price, but am unsure of them, if anyone knows anything please let me know, thanks.
Old Apr 14, 2010 | 08:12 AM
Doug's Avatar
The thread size on the Jaguar nuts is common so that won't be a problem. As for the diameter and length of the part of the lugnut that acutally goes thru the wheel....I'm not sure if that's Jaguar-specific.
I'd visit a local tire store that does a lot of aftermarket wheel business. They'll probably have umpteen different types of lugnuts that you can look at and try before you buy.
Old Apr 14, 2010 | 12:50 PM
When you say stuck, do you mean unturnable (as in too tight) or jammed (as in don't fit, can't get a wrench on them).
If they have been hammered on with an air gun you might well have a problem with steel nuts and alloy wheels. You really should see that you/your garage finishes tightening by hand with a torque wrench, and then checking again after a few days.
Over enthusiastic use of the gun can ruin alloys, even as far as cracking the rims.
There are many schools of thought as regarding the use of an anti sieze compound, I won't offer any advice one way or the other.
However your nuts need to be really clean and dust/rust free.
With the wheel off, screw and unscrew the nuts back into the hub a few times to help clear the threads.
Old Apr 14, 2010 | 03:26 PM
does anyone know the exact size of the 95-96 short style lug nuts, I wanan compare them to the size with the aftermarket ones, thanks.
Old Apr 15, 2010 | 02:52 AM
Cadillac's Avatar
I got another tyre valve cap and the cap came with a lubricant that prevents the caps from getting stuck ,may be such a lubricant would also be good for jamming issue but adversely it might affect the tightness of them which could cause some disasters
aholbro1
Dec 29, 2024 06:46 PM
way2far
Aug 31, 2022 09:26 AM
Neil1664
Jan 20, 2022 08:59 PM
b1mcp
Sep 13, 2015 07:31 PM
iownme
Sep 11, 2015 02:57 AM
