Rack and pinion seals
Old Feb 12, 2024 | 01:01 PM
cdma's Avatar
Default Rack and pinion seals
So I just replaced my rack, and it did not come with the seals that are where the lines come into the rack. Does anyone know what those are called or where I can get them?
Old Feb 12, 2024 | 01:20 PM
Parker 7's Avatar
Was the servo not shipped / installed ?
See page 53 for type 7852 with servo
See page 47 for key to numbers in figures
and
Genuine Steering Hoses-6 Cylinder (less 6.0 Litre) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
File Type: pdf
Old Feb 12, 2024 | 01:30 PM
cdma's Avatar
So part 103 is what I need but how do I figure out what the "part number" is or where to get them
Old Feb 12, 2024 | 02:37 PM
Parker 7's Avatar
You have the pipes 101 and 102 and just need the O - rings ? ( 103 X 4 )
The pipes appear to be of the assembly and not car connections
Any contact with those who overhauled the assembly ?
Old Feb 12, 2024 | 03:01 PM
Parker 7's Avatar
Steering and Chassis Parts - ZF Aftermarket
Old Feb 12, 2024 | 07:49 PM
cdma's Avatar
I used Detroit Axle through Amazon.
Amazon Amazon
Old Feb 12, 2024 | 08:38 PM
Parker 7's Avatar
I never got anywhere in the ZF Aftermarket website , probably need login passward
Old Feb 13, 2024 | 09:14 AM
cdma's Avatar
I just ordered a seal kit with 100's of seals, so I am hoping. two of them will fit.
Old Feb 13, 2024 | 10:44 AM
PBoudr's Avatar
Originally Posted by cdma
I used Detroit Axle through Amazon. https://www.amazon.com/dp/B019VI6V3Q...roduct_details
I need a new rack. Mine started leaking pretty bad from the passenger side seal. I'd be interested how your's goes with the Detroit Axle parts. I was thinking of getting mine from there as well.
Old Feb 14, 2024 | 07:27 AM
cdma's Avatar
Got it installed and have to change my shocks but as soon as I get those changed out, which I am almost done, I will let you know.
Old Feb 14, 2024 | 07:54 AM
Parker 7's Avatar
I think you were involved earlier with the steering wheel coupling and the adjustment index mark on the rack on installation
Old Feb 14, 2024 | 09:24 AM
cdma's Avatar
My plan is to get it really close so that I can get it down to get the front end aligned.
imagineaudio
Nov 15, 2017 06:06 PM
juha.
XJ40 ( XJ81 )
Jun 8, 2017 11:52 AM
White Jaguar
Jun 25, 2013 06:48 AM
MLRocafella85
Apr 2, 2011 05:44 PM
