Radiator XJR6
Old Jan 12, 2018 | 10:00 PM
charlie.p's Avatar
Default Radiator XJR6
Hi, my radiator, like me, is showing signs of age. The header tank is turning brown and the ridge on the top hose spigot has a bit missing. Searching for a new replacement radiator is problematic because...um they are no longer held in stock by anybody I have contacted so far. The difference as I understand it, is the transmission cooler pipes connection. XJRs run a GM gearbox which is the reason.
Has anybody tried modifying the standard x300 radiator to work in an XJR6, or is that a No-No? Thanks for reading.
Old Jan 12, 2018 | 10:41 PM
AL NZ's Avatar
I had an aluminum custom radiator made for my 3.2 Daimler, for NZD $1100 about 3 yrs ago. That was only slightly more expensive than a brand new plastic Jaguar one imported from UK..
Old Jan 13, 2018 | 09:17 AM
Ric in RVA's Avatar
I am sure there is plenty of room up front for an air/oil trans cooler.
You would have to make some new hoses but you can find that any town of any size.
You would lose the ability of the radiator to WARM the transmission up in super cold weather (yes that is one of the benefits of a water/air cooler as the trans will stay cold a long time if driven lightly in cold weather.....not an issue in Queensland I assume???).
You will probably have better transmission cooling than before though.
Old Jan 13, 2018 | 10:55 AM
countyjag's Avatar
The only difference between the XJR radiator and the rest is that the connectors for the transmission oil cooler are the opposite, ie male rather than female or vice versa, I cant remember which.
One solution therefore is to fit a normally aspirated radiator and find converter couplings to allow the transmission cooler to be connected up.
Alternatively, it is not difficult to find a radiator shop who will recore the radiator with a brass core, rather than aluminium.
I chose the latter solution a few years ago, and it has been fine, and avoided a significant outlay for a custom radiator.
Old Jan 13, 2018 | 11:14 AM
Qvhk's Avatar
I didn't know that X300 radiators have different versions. According to Jaguar Classic parts, the three versions are
(a) MNA4190EB [still available for GBP294] for all X300s with Manual Transmission;
(b) MNA4190AA [no longer available] for Supercharged X300 with Auto Transmission;
(c) MNA4190DB [still available for GBP435] for non-supercharged X300s with Auto Transmission.
Fortunately, aftermarket versions of MNA4190DB are also available, for about GBP280.
Old Jan 13, 2018 | 01:20 PM
countyjag's Avatar
Sorry, I was overlooking the manual versions, which dont have a transmission oil cooler, obviously.
The only difference between the auto transmission versions of the radiator between normally aspirated and supercharged is with the "polarity" of the couplings for the transmission oil cooler ( as the Supercharged has a different transmission). All other dimensions are identical.
Old Jan 13, 2018 | 04:55 PM
charlie.p's Avatar
Default Aluminum would be nice
thanks AL, that's an option. I rang a company in Brisbane but their quote was
2-2.5 thousand....eeeek
Old Jan 13, 2018 | 05:06 PM
charlie.p's Avatar
Ric, thanks i didn't know about the other effects of the water/oil trans cooler. Space in a SC car, as I am sure you are aware is at a premium under the bonnet!
Old Jan 13, 2018 | 11:11 PM
Qvhk's Avatar
Radiators are low-tech consumables so many have learned to fabricate one locally, as no matter how much cheaper you can find factory original or aftermarket online, the size and weight of the radiator mean shipment across the continents is going to hurt.
Old Apr 10, 2018 | 05:56 AM
someguywithajag's Avatar
Is it possible to remove the connectors from a s/c radiator and attach them to a n/a radiator?
slmskrs
24
Dec 23, 2024 12:04 AM
andyXJR
Jun 24, 2016 05:34 AM
Tipptone
Sep 16, 2015 07:39 AM
tomcaine
Apr 29, 2008 11:23 AM
XjJagXjJeepDriver
Feb 8, 2008 10:38 AM
