Random cooling fan operation
Old May 18, 2020 | 03:35 PM
xalty's Avatar
Default Random cooling fan operation
Drove through a nasty rainstorm yesterday. Woke up to the cooling fan running, clock lit and 12V in cig lighter all intermittently turning on at the same time. Car starts and drives without issue. Corroded grounds or what else could this be?
97 XJ6L
Old May 18, 2020 | 03:45 PM
Parker 2's Avatar
If the fan control relay module if mounted upside down can get water into it flooding the relay contacts
You can shake the relay and hear it
If the water stays in the relay module it will ruin it from corrosion
The black relay module from a X308 will not work for the white X300 version
Old May 19, 2020 | 05:18 PM
xalty's Avatar
Cleaned it, found only some dirt.
Either way the car’s back to normal.
Davidvdm
Apr 21, 2015 03:41 PM
georgia boy
Jan 25, 2011 12:55 PM
MTW
Mar 23, 2010 04:59 PM
teflondon
May 8, 2009 09:01 AM
