RE: Jaguar Supercharger Belt Fitting (1995)
Old Mar 8, 2008 | 09:05 AM
jag_genius's Avatar
Default RE: Jaguar Supercharger Belt Fitting (1995)
if you tighten it as much as humanly possible then that's to tight.. you can where out your supercharger front bearing.i wud back off a bit..and check.. if pulley you are talking about is the supercharger pully then yes it will have resistance from the rotors in the super charger.. and belts dont usually fall off unless they brake off.. i wud check for play on the tensioner pulley.
but idlers pulley shoud spin freely.. by hand with no belt on of course.. and have no play in it.. if there is replace it..
Old Mar 9, 2008 | 02:19 PM
badmojo's Avatar
Maybe it's another belt that is sqeaking?
Old Mar 10, 2008 | 05:04 PM
ken@britishparts.com's Avatar
Perhaps the tight idler is what's causing the problem. It could have been the reason the old belt broke or what have you.
Old Apr 8, 2024 | 07:42 PM
RonXJR's Avatar
When I took the supercharger belt off on my xjr6, I can rotate all the pulleys freely without any noise. I can hand turn the supercharger pulley as well. The plastic pulley contains bearing inside and you can torque it down per spec. The belt tension adjustment should be done 1) loosen the bolt on the adjuster pulley, 2) turn the adjustment rod for the proper tension and 3) torque down the bolt on the adjuster pulley. Check all the pulleys and the belt alignment to see if they are all inline.
Old Apr 8, 2024 | 08:13 PM
Parker 7's Avatar
The idler pulley bearings if the same for the separate A / C compressor belt shouldn't last forever , 13 dollar ( Pre - Covid , PC ) common Gates # X
The center bearing bolt should have no effect on clamping the bearing too tight but has to be loosed in order to adjust the long treaded adjustment bolt
The treads can be frozen inside the treading block and let me know if yours is the same as I overcame that obstacle
There is a cheap belt tension gauge and the spec should be somewhere
To test the existing tensioner pully get some grease in the bearing and see if it disappears , temporary test fix
A sweak can also get in the area of a harmonic balancer slip ( under load ) with easy test
You don't have to remove belts for test , pic from AL as I don't have the SC engine
giandanielxk8
May 31, 2018 10:05 AM
rocklandjag
Feb 25, 2015 04:45 PM
vincent661983
Dec 26, 2014 11:40 AM
Double Tap
Sep 21, 2010 03:03 AM
