Rear Bumper
Old Sep 6, 2011 | 04:51 PM
Simprof's Avatar
Default Rear Bumper
I wonder if anyone can let me know how to ajust the rear bumper for some reason the drivers side of the rear bumber has a gap of about 1/2 to 3/4" the bumper seems tight at the back of the car amd the opposite side is fine too. Is there a way to get it in place and then tighten what ever is loose?
Old Sep 7, 2011 | 04:04 PM
ken@britishparts.com's Avatar
More than likely someone tapped you when parked or you bumped something in reverse. The shock in the back is probably depressed in slightly on one side. It should pull out which may take some force. You may need to remove the bumper, pull the shock out then, and then reattach. You may use a small metal screw as a shear pin to hold the shock in the extended position.
Old Sep 8, 2011 | 04:53 PM
Simprof's Avatar
Thank you I will check that over the weekend. Mind I dont see marks on the bumper but you never know..
H20boy
Dec 24, 2024 03:23 PM
AlexSaltLife
Jan 23, 2023 10:41 AM
Marque
Sep 14, 2015 11:17 AM
avern1
Sep 6, 2015 04:22 PM
prettydaim
Sep 4, 2015 09:13 AM
