Rear center stop light came off
Old Apr 12, 2018 | 12:57 PM
xjfourty's Avatar
Default Rear center stop light came off
so the rear center window stop light came off.
should a drop of loctite do the trick to attach it back?
a thin stripe of gasted came off too but can’t figure out where it was previously located on the lamp holder
thank you
Old Apr 12, 2018 | 02:15 PM
smartobject's Avatar
It was most likely attached with 2-sided tape. You should clean the old tape off the surfaces and apply some new 2-sided tape. You can use a 2-sided tape for emblems.
Old Apr 12, 2018 | 04:50 PM
Lady Penelope's Avatar
I think it is the same as the glue for a rear view mirror . I tried to get mine off to clean it , nope . Glue found at parts store , must remove the old glue . Follow instructions carefully and don't get it on your fingers , catalyst is very bad for your kidneys and liver .
Old Apr 13, 2018 | 12:55 PM
aholbro1's Avatar
There's a how-to on here somewhere...I've seen it before....I'll post a link in a week or two when I get around to this...I've got 3 of them that have fallen off!
Old Apr 13, 2018 | 01:25 PM
motorcarman's Avatar
Glass companies can glue it back. They have experience with bonding things to glass.
Jaguar issued a TSB for us back-in-the-day.
The parts dept provided the kit. The same adhesive is used for both rear view mirror and HMSL.
bob
File Type: pdf
Old Apr 13, 2018 | 03:49 PM
al_roethlisberger's Avatar
Glass companies can probably get it to stay, but my (and many other DIY owners) have had poor luck having the tabs stay glued long-term after they initially fall off.
I've followed the various instructions and used the correct adhesive, but they just fall off in a year or two again.
I'm trying to rig up a more substantial mounting using ABS plastic as a frame and 2 sided 3M adhesive tape, then bolting the light to the ABS. I haven't gone beyond the mental design stages though.
For now, my HMSL is sitting on an old towel on the package shelf.
.....really dumb design IMHO.
Drossvet
Oct 21, 2016 09:27 AM
equicor
Oct 3, 2016 09:30 PM
JimC64
Sep 10, 2009 12:44 PM
Aug 1, 2006 04:09 AM
Jan 22, 2006 12:18 AM
