Rear edge Boot Lid Jammed hard against body
Old Oct 27, 2024 | 10:02 PM
VickTrader's Avatar
Default Rear edge Boot Lid Jammed hard against body
So today, had to pull up the boot lid so hard 3-4 times until it 'popped' open. The Rear edge of my boot Lis Jammed against body, and tightly, when closed.
What adjustments can I make on the hinges and bolts to fix ?
Sides are normal gap back is Jammed on back edge 3-4 pulls to get it will pop free and open
rear has no gap; water won't even go in
Old Oct 27, 2024 | 10:58 PM
Parker 7's Avatar
The curved hinges should have without looking a serrated mount to make adjustment
how you would hold the trunk up to adjust is another matter
See if you can mark your present serration position before " loosing it "
Something like this generic pic off the internet , not X300
Old Oct 28, 2024 | 12:33 AM
watto700's Avatar
G'day Vick,
The boot lid is attached to the hinges on each side by two bolts which pass through the hinge arm into a bracket with captive nuts and it seems that if you loosen these bolts you may be able to reposition the boot lid.
The boot hinge is attached to the car body by four bolts each side and the doesn't appear to be any scope for adjustment there though there may be some.
What I would do is remove the boot lid liner, to get a better idea of what is needed and what can be adjusted, and then with the necessary bolts just loose enough to move the boot lid a bit conscript a volunteer, with a torch, to curl up in the boot while you close the lid and reposition it and when you are happy have your assistant tighten some of the bolts. Then open the boot to release your claustrophobic friend and tighten the remainder of the bolts. Your problem should no be solved.
Cheers,
Jeff.
Old Jul 29, 2025 | 10:10 PM
VickTrader's Avatar
Jeff,
The hinges have single hole bolt openings, I got the bolts loose but was only able to move the boot lid a very bit to the rear, but that was enough, and your idea Worked !! Opens and closes just fine now.
Thanks for the advice.
Old Jul 30, 2025 | 01:40 AM
watto700's Avatar
G'day Vick,
Great that you got your trunk/boot adjusted so it fits.
Interesting though, I just checked my car and each hinge definitely has two bolts attaching them to the trunk/boot lid.
Cheers,
Jeff.
Old Jul 30, 2025 | 09:43 PM
VickTrader's Avatar
yes I meant that the bolt holes are a single round shape, not oblong like some, so not much wiggle room
Old Jul 31, 2025 | 04:17 AM
watto700's Avatar
G’day Vick,
Yeah you’re right there is not much wiggle room but enough to sort your problem. 👍
Cheers,
Jeff.
Horse on a Beaxh Ball
Aug 1, 2024 10:28 AM
Spud Maat
Oct 30, 2023 06:02 AM
Bob Hornby
Jun 4, 2021 07:39 PM
Shed_1978
Mark V - X 420G
May 28, 2019 08:26 AM
jighead45
Feb 22, 2016 09:54 AM
