rear hub and output shaft bearings - want alternative part numbers
Old Jan 29, 2015 | 01:36 PM
plums's Avatar
Default rear hub and output shaft bearings - want alternative part numbers
These numbers were posted in another thread:
output shaft bearings: Napa (SKF) 6207-J
output shaft seal: Napa SKF Oil Seal number 18662
can anyone fill in the following:
output shaft o-ring
fulcrum bearings
rear hub inner bearing
rear hub outer bearing
rear hub inner seal
rear hub outer seal
The parts can easily be found in JEPC, but the thrifty side of me pales
at the prices.
Old Jan 29, 2015 | 05:00 PM
Don B's Avatar
Hi Plums,
Enter your car info at this website and SKF will fill in most of the blanks for you:
SKF Online Parts Catalog
And this cross-reference is sometimes handy:
http://www.skf.com/binary/79-66347/457013.pdf
The Timken part finder is here:
http://www.showmetheparts.com/timken/
Using the kit numbers will typically get you all the parts you need. I seem to recall that neither SKF nor Timken list some oil seals or the diff output shaft collar separately. You can shop around industrial suppliers and industrial bearing suppliers, but they often make it difficult to match SKF's & Timken's numbers directly. I've always found Coventry West to be competitive on price and they usually have the kits in stock. I assume the same is true for SNG Barratt, Jagbits and Welsh Enterprises, who offer discounts to forum members.
Cheers,
Don
Old Jan 29, 2015 | 06:15 PM
plums's Avatar
Thanks for the links.
The SKF cross-reference seems to be much more
complete than the Timken cross-reference.
The SKF partfinder is a showmetheparts.com application.
Very buggy, but it yielded a few numbers after changing
browsers.
Copy/paste won't work from that site. But a screenshot
with my additions is attached.
Further input welcome!
Attached Thumbnails rear hub and output shaft bearings - want alternative part numbers-x300-bearings.gif
Old Jan 30, 2015 | 11:37 AM
aholbro1's Avatar
Hey Plums, I recently did all four corners, though didn't mess with the fulcrum bearings.
I belatedly realized I was missing a couple of races, which I obtained from Amazon:
Amazon.com: Timken LM503310 Wheel Bearing: Automotive Amazon.com: Timken LM503310 Wheel Bearing: Automotive
Otherwise, I used these from RockAuto.com:
CENTRIC41720003 (417.20003)Wheel Seal$ 1.83$ 0.002$ 3.66
TIMKENSET45Wheel Bearing$ 9.03$ 0.002$ 18.06
TIMKENLM503349AWheel Bearing$ 10.91$ 0.002$ 21.82
TIMKENSET8Wheel Bearing$ 4.90$ 0.002$ 9.80
TIMKENSET17Wheel Bearing$ 5.78$ 0.002$ 11.56
BECK/ARNLEY0523740 (052-3740)Wheel Seal$ 7.02$ 0.002$ 14.04
Old Jan 30, 2015 | 04:13 PM
plums's Avatar
Thumbs up thanks!
That pretty much completes the list for future reference.
Thanks for taking the time to copy all of that over.
This rear suspension is going to nickel and dime me
to death though
A couple of bushings here, a few bearings there ...
and that's on top of the Auburn posi. Looks like
the posi was just the tip of the iceberg.
That rear subframe assembly has a lot of parts!
Old Aug 10, 2015 | 10:47 PM
ReluctantMechanic's Avatar
Plums - the SKC bearing for a X-308 XJR - differential output shaft?
My bearing is not bad but leaking. Can I just change the o-ring? I cant find where it goes in my shopmanual - behind the circle clip which has to back on before the bearing. Can I reused the circle clip and squeeze the o-ring over the end of the shaft?
Old Aug 11, 2015 | 03:59 PM
plums's Avatar
There was a discussion last week in the x308 section about this job.
There are links in there to various descriptions and photos of the job
showing procedures, seals, etc.
Old Jan 6, 2018 | 12:11 AM
MPDano's Avatar
output shaft o-ring
fulcrum bearings
rear hub inner seal
rear hub outer seal
at the prices.
I too need to do this job. I didn't see any part number for the o-ring in the rest of the thread. Also, should there be a bearing retainer collar in the output shaft rebuild?
Old Jan 6, 2018 | 12:27 AM
Lady Penelope's Avatar
I personally would not go cheap on the bearing and go with SKF or Timken , Ebay beware
Started a pdf doc on it below a few months back :
https://www.jaguarclassicparts.com/u...ponents-normal
Question if there is a difference on normal vs, limited slip differential as I haven't checked
Old Jan 6, 2018 | 07:42 AM
MPDano's Avatar
Yes, this is exactly what i was going to do. I'm buying the SKF bearings and seals, just need to know the part numbers for the o-ring and retaining collar.
Old Jan 6, 2018 | 08:03 AM
MPDano's Avatar
Oops, didn't see your pdf. Part numbers were there. Thanks for that.
Here is a complete list if parts to do the output shaft seals on both sides.
2 O-Rings: part number JLM621
2 Collars: part number JLM615
2 output shaft bearings: SKF 6207-J
2 output shaft seals: SKF 18662
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
